Converting lat/long distance to miles.
Camden Daily
cdaily at GMAIL.COM
Wed Jan 26 17:15:38 EST 2005
Ok. I had axed all my projection blocks because I'd converted all my
shapefiles to lat/long (epsg:4326) using ogr2ogr, so I figured I
didn't need them. Should I still add a projection block to the map
and each layer?
My map file has a 'units' set to dd, since that is how I set my
extents (and I need to set them that way, since I'm centering off a
given lat/long point in mapscript).
Could I set the extents in mapscript using dd, and then change the
units to miles for my distance calculations?
