PHP Query By Attributes - queryMap ?
Steve Lehr
lehrs at ERAU.EDU
Wed Jan 26 16:58:07 PST 2005
I found the parcels I'm sending in but they are not highlighting as defined
in the QUERYMAP; it seems I don't have an association linking the QUERYMAP
defined in the map file with parcel layer that I'm querying, ie to mark them
as to be highlighted. I can't find the appropriate method to link the layer
with the querymap (if I need to do)
How do I associate the QUERYMAP definition in the map file with the parcel
layer in the PHP code (or in the map file?)
Abe had a last second thought ..
Now that I look at it, the last thing you may have been missing was the
mapObj::queryMap() method. Anyhow, I hope this helps.
But I'm not sure what to do with this
Steven Lehr
Assistant Professor
Freshmen Program
College of Engineering
Embry-Riddle Aeronautical University (LB159)
600 S. Clyde Morris Blvd.
Daytona Beach, FL 32114-3900
386-226-7740
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
Behalf Of Abe Gillespie
Sent: Sunday, January 23, 2005 1:45 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] PHP Highlight list of Parcels Passed In
Ok, since this list has been so helpful and generous to me in the past,
here is an exhaustive example. I hope this will finally get you going.
Disclaimer: I'm doing this all from memory and w/o testing so there may be a
few errors.
Setup a map file like this:
MAP
NAME "Parcel Query"
STATUS on
EXTENT xmin ymin xmax ymax
SIZE 300 300
SHAPEPATH "/data_path"
IMAGETYPE png
IMAGECOLOR 255 255 255
QUERYMAP
STYLE hilite
COLOR 255 0 0
END
LAYER
NAME "Parcels"
DATA "parcels"
CLASS
OUTLINECOLOR 0 255 0
END
TEMPLATE "x"
END
END
Setup a web page like this:
<html>
<head>
$parcel_ids = "1|2|3|4|5";
if (PHP_OS == "WINNT" || PHP_OS == "WIN32")
dl("php_mapscript.dll");
else
dl("php_mapscript.so");
$map = ms_newMapObj("parcels.map");
$layer = $map->getLayerByName("parcels");
// Query.
$layer->queryByAttributes("", "/".$parcel_ids."/", MS_MULTIPLE);
// If you want to avoid errors when no matches are found use the ampersand
// in the above statement like this: @$layer->queryByAttributes();
// Render an image and get its URL.
$img = $map->drawQuery();
$url = $img->saveWebImage(MS_PNG, 1, 1, 0);
$img->free();
</head>
<body>
<img src="<? echo $url; ?>" />
if ($layer->getNumResults() > 0)
echo $layer->getNumResults()." parcels found.";
else
echo "No parcels found.";
</body>
</html>
-Abe
On Jan 22, 2005, at 10:07 PM, Steve Lehr wrote:
Abe:
I appreciate the help, still not getting it though. I'm wondering if I
need
to draw out the map after rendering? I've sceen other posts but no real
solutions...
I'll start from scratch rather then trying to reuse something I have. If
anyone else has a more complete example I'd really appreciate seeing it.
Thanks
Steven Lehr
Assistant Professor
Freshmen Program
386-226-7740
Sent: Saturday, January 22, 2005 8:22 PM
In
Something else I noticed. You shouldn't even have to setup a separate
layer to show queried parcels (though there are ways to do this). I
suggest starting out with one layer that renders queried and
non-queried parcels at the same time. Once you get the hang of that
then you can do two different layers (if you still even want to). Make
the layer like this:
LAYER
NAME "parcels"
DATA "parcels"
STATUS on
TYPE polygon
CLASS
END
TEMPLATE "x" # Must be present to query on (though "x" means
absolutely nothing).
END
The above layer will render all your parcels green outline with hollow
fill. Then when you use the PHP code to query it will render your
queried parcels red. This assumes you have QUERYMAP setup correctly.
-Abe
On Jan 22, 2005, at 7:12 PM, Steve Lehr wrote:
Abe I've never used the QUERY MAP before, I tried putting it in the
layer
and it did not like that?
My initial layer looks like:
I changed my code to pass Pipe delimited.
But I'm not quite certian I'm still getting what I need to do to my
.map.
Thanks for the help..below is the layer repeated my EXPRESSION is
trashed I
realize.
LAYER
NAME "selected_parcels"
DATA parcels
STATUS DEFAULT
TYPE POLYGON
CLASSITEM QPID
CLASS
EXPRESSION "/%parcels%/"
COLOR 255 0 0
END
END
Steven Lehr
Assistant Professor
Freshmen Program
386-226-7740
Sent: Saturday, January 22, 2005 7:05 PM
Passed
In
For the red you need to setup the QUERYMAP. For the PHP it will be
something like this:
$target =
use_appropriate_string_func_to_conver_semi_to_pipe($parcels);
// $target should look like "1|2|3|4" ... where the numbers are the
IDs.
$layer->queryByAttributes("parcel_id_field", "/".$target."/",
MS_MULTIPLE);
Also, don't forget to add the TEMPLATE "x" tag in your LAYER
definition.
I'm not a RegEx expert, so someone please put me in check if I'm
leading Steven astray.
-Abe
On Jan 22, 2005, at 6:37 PM, Steve Lehr wrote:
I'm trying to write some PHP that I can send extents and list of
parcels to
get it to highlight the parcels.
I'd like to highlight all the found parcels in RED.
My php gets a variable by post called parcels and contains at this
time a
semi colon delimited list of ids in the attribute column QPID of the
parcels.dbf.
LAYER
DATA parcels
STATUS DEFAULT
TYPE POLYGON
CLASSITEM QPID
CLASS
COLOR 255 0 0
END
END
I've got my extents. I've got the list of parcels. Now I want to
highlight
the list of parcels with something like the below. But I have to do
something in php to take that ; delimited list and the turn on all
the
matching attributes. (I belive its a QUERYMAP with MULTIPLE_SELECT)
but I'm
having trouble getting my brain around what I need to code - might
someone
have a sample.
Thanks
Steven Lehr
Assistant Professor
Freshmen Program
386-226-7740
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050126/1018a9d6/attachment.htm>
More information about the MapServer-users
