Zoom to custom extent - PHP
William Bronsema
wbronsema at DMSOLUTIONS.CA
Thu Jan 27 03:38:25 PST 2005
Kevin,
PHP variables are case sensitive. I just took a quick peek at the code you
sent me earlier. Your app uses $http_form_vars not $HTTP_FORM_VARS.
Try changing to $http_form_vars and let me know how it goes.
Regards,
Bill
________________________________________________
William A. Bronsema, C.E.T.
Applications and Software Development,
DM Solutions Group Inc.
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at lists.umn.edu] On
> Behalf Of Kevin Grootendorst
> Sent: January 26, 2005 3:42 PM
> To: MAPSERVER-USERS at lists.umn.edu
> Subject: Re: [UMN_MAPSERVER-USERS] Zoom to custom extent - PHP
> Bill,
> I added that code, right before the IF statement.
> There was no output...
> Does that tell us that ($HTTP_FORM_VARS) is null?
> On Wed, 26 Jan 2005 15:20:01 -0500, William Bronsema
> <wbronsema at DMSOLUTIONS.CA> wrote:
> >Kevin,
> >It sounds like $HTTP_FORM_VARS['doQuickZoom'] is not being set.
> >Add this:
> >echo '<pre>';
> >print_r( $HTTP_FORM_VARS );
> >echo '</pre>';
> >just before the if statement and send me the output for both an intial
> page
> >load and quickzoom page load. This will tell us exactly what is being
> set
> >(or not set ;) ).
> >Regards,
> >Bill
> >> From: Kevin Grootendorst [mailto:kgrootendorst at BAIRD.COM]
> >> Sent: January 26, 2005 3:12 PM
> >> To: MAPSERVER-USERS at LISTS.UMN.EDU; William Bronsema
> >> Subject: Re: Zoom to custom extent - PHP
> >> Bill,
> >> OK. This makes sense.
> >> But, using the following statement:
> >> If ( isset( $HTTP_FORM_VARS['doQuickZoom']) && $HTTP_FORM_VARS
> >> ['doQuickZoom'] == "1" )
> >> This returns a false, and the QuickZoom php code is not executed.
> >> Using this statement:
> >> ['doQuickZoom'] == "" )
> >> Also returns a false.
> >> If ($HTTP_FORM_VARS['doQuickZoom'] == "")
> >> Returns a TRUE - and the php code is executed. But the map does not
> draw
> >> to the desired extents. It just refreshes the current map extent.
> >> Thanks.
> >> Kevin
> >> On Wed, 26 Jan 2005 14:52:35 -0500, William Bronsema
> >> >Kevin,
> >> >doQuickZoom is supposed to go back to "". echo
> >> >$HTTP_FORM_VARS['doQuickZoom'] before your "If ( isset(
> >> >$HTTP_FORM_VARS['doQuickZoom'])...." statement to see what I mean. It
> >> >should only echo 1 after a quick zoom is called. You only want it to
> be
> >> 1
> >> >when you want to do a quick zoom. Make sense?
> >> >Is the PHP code being called to perform the quick zoom and the map is
> >> just
> >> >not zooming? Or is the PHP code not being called?
> >> >Regards,
> >> >Bill
More information about the MapServer-users
