layers are not drawn
Alex Chimarios
alhim at INTRACOM.GR
Thu Jan 27 08:50:50 EST 2005
I am trying to port mapscript to arm-linux for iPAQ PDA in order to create a
demo application loading just one map.
I have cross-compiled for arm-linux the following libraries :
proj-4.4.7
gdal-1-1-9
freetype2
gd-2.0.25 with png, jpeg and freetype support
I have used libpng ,lipjpeg, libX11 and libxpm from binaries coming with
Familiar Linux distro for PDA.
Finally I cross-compiled mapserver and mapscript.
However, when I try to run a simple program in mapscript, the map is drwan
without any layers on it!!! Just the background .
Can you give me a tip ? I think it may be a lib error. Which lib is
responsible if layers are not drawn ?
p.s : this is my map file :
MAP
NAME Mediteranean
STATUS ON
SIZE 600 600
EXTENT 2.5256 21.5595 34.1734 53.2078
SHAPEPATH "/root/gistest"
IMAGECOLOR 50 200 200
IMAGETYPE PNG
INTERLACE ON
PROJECTION
"init=epsg:4326"
END
WEB
IMAGEPATH "/root/"
IMAGEURL "/root/"
END
LAYER
NAME "cities"
STATUS ON
DATA cities
TYPE POINT
PROJECTION
"init=epsg:4326"
END
LABELITEM "NAME"
CLASS
STYLE
COLOR 255 255 0
SYMBOL "/root/gistest/ctyhwy.png"
END
LABEL
COLOR 255 255 0
SIZE tiny
#FONT arial
POSITION CL
PARTIALS TRUE
ANTIALIAS TRUE
MINDISTANCE 30
BUFFER 1
END
END
END
