PHP-Mapserver query result
Palanisamy, Giri
palanisamyg at ORNL.GOV
Thu Jan 27 09:10:00 EST 2005
Hi List,
Sorry for this repeated postings, but I still could not figure out a
solution, I would really appreciate if any one can give me some idea for
the problem discussed below.
I just got the php-mapscript (rosa) GMap sample application running, I
would like to display the query results in a new page, the sample
application does it in the same page (when I press the "info" button and
click some points on the map it displays the city names in the same
page)? I could achieve this in JBox-mapscript application by setting the
TEMPLATE in the class object in the .map file as
LAYER
NAME fluxnet_ll_use
METADATA
"DESCRIPTION" "Sites"
"RESULT_FIELDS" "SITE_LABEL NETWORK COUNTRY STATUS IGBPCLSS CLIMATE
LONG LAT "
END
GROUP MODIS
TYPE POINT
DATA f264
STATUS DEFAULT
PROJECTION
"proj=longlat"
"ellps=GRS80"
"no_defs"
END
CLASS
NAME 'FLUXNET Sites'
COLOR 0 0 255
SYMBOL 'triangle'
SIZE 10
TEMPLATE "fluxsites.phtml"
END
TOLERANCE 5
END
I would really appreciate if anyone can tell me how to do this with the
php-mapscript (rosa)?
Thanks
Giri
