layers are not drawn
Alexandros Chimarios
alhim at INTRACOM.GR
Thu Jan 27 09:09:27 EST 2005
Thanx for answering Jeff,
actually I don't use the mapserv CGI application but Python mapscript.
Therefore I dont think so that the problem has to do with the user's
permisions. I run everything as a root. There must be a problem with some lib
propably.
On Thursday 27 January 2005 16:07, Jeff Portwine wrote:
> I notice you specified your paths as /root/... I am not familiar with
> your OS or how you've setup your filesystem and thus I am not sure if /root
> is referring to the web server root or your actual root directory but just
> in case I thought I'd mention to make sure that those directories are
> readable by the "web user"... whether that user is nobody (as is often the
> case with apache) or some other user name. I think if those permissions
> are bad it would cause the behavior you described...
> I'm still a newbie so I'll defer to the experts for any suggestions beyond
> that :)
> -Jeff
> ----- Original Message -----
> From: "Alex Chimarios" <alhim at INTRACOM.GR>
> To: <MAPSERVER-USERS at LISTS.UMN.EDU>
> Sent: Thursday, January 27, 2005 8:50 AM
> Subject: [UMN_MAPSERVER-USERS] layers are not drawn
> > Hi,
> > I am trying to port mapscript to arm-linux for iPAQ PDA in order to
> > create a
> > demo application loading just one map.
> > I have cross-compiled for arm-linux the following libraries :
> > proj-4.4.7
> > gdal-1-1-9
> > freetype2
> > gd-2.0.25 with png, jpeg and freetype support
> > I have used libpng ,lipjpeg, libX11 and libxpm from binaries coming with
> > Familiar Linux distro for PDA.
> > Finally I cross-compiled mapserver and mapscript.
> > However, when I try to run a simple program in mapscript, the map is
> > drwan without any layers on it!!! Just the background .
> > Can you give me a tip ? I think it may be a lib error. Which lib is
> > responsible if layers are not drawn ?
> > p.s : this is my map file :
> > MAP
> > NAME Mediteranean
> > STATUS ON
> > SIZE 600 600
> > EXTENT 2.5256 21.5595 34.1734 53.2078
> > SHAPEPATH "/root/gistest"
> > IMAGECOLOR 50 200 200
> > IMAGETYPE PNG
> > INTERLACE ON
> > PROJECTION
> > "init=epsg:4326"
> > END
> > WEB
> > IMAGEPATH "/root/"
> > IMAGEURL "/root/"
> > END
> > LAYER
> > NAME "cities"
> > STATUS ON
> > DATA cities
> > TYPE POINT
> > PROJECTION
> > "init=epsg:4326"
> > END
> > LABELITEM "NAME"
> > CLASS
> > STYLE
> > COLOR 255 255 0
> > SYMBOL "/root/gistest/ctyhwy.png"
> > END
> > LABEL
> > COLOR 255 255 0
> > SIZE tiny
> > #FONT arial
> > POSITION CL
> > PARTIALS TRUE
> > ANTIALIAS TRUE
> > MINDISTANCE 30
> > BUFFER 1
> > END
> > END
> > END
