Zoom to custom extent - PHP - SOLVED
Kevin Grootendorst
kgrootendorst at BAIRD.COM
Thu Jan 27 11:58:14 EST 2005
Bill,
Finally, I was able to get my application working properly.
After I changed $HTTP_FORM_VARS to $http_form_vars, I moved the code in my
app.php file closer to the top of the file.
The application works perfectly.
Thanks for all your help and your php tips, it's greatly appreciated.
Regards,
Kevin
On Thu, 27 Jan 2005 06:38:25 -0500, William Bronsema
<wbronsema at DMSOLUTIONS.CA> wrote:
>Kevin,
>PHP variables are case sensitive. I just took a quick peek at the code you
>sent me earlier. Your app uses $http_form_vars not $HTTP_FORM_VARS.
>Try changing to $http_form_vars and let me know how it goes.
>Regards,
>Bill
>________________________________________________
>William A. Bronsema, C.E.T.
>Applications and Software Development,
>DM Solutions Group Inc.
>> -----Original Message-----
>> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at lists.umn.edu] On
>> Behalf Of Kevin Grootendorst
>> Sent: January 26, 2005 3:42 PM
>> To: MAPSERVER-USERS at lists.umn.edu
>> Subject: Re: [UMN_MAPSERVER-USERS] Zoom to custom extent - PHP
>> Bill,
>> I added that code, right before the IF statement.
>> There was no output...
>> Does that tell us that ($HTTP_FORM_VARS) is null?
>> On Wed, 26 Jan 2005 15:20:01 -0500, William Bronsema
>> >Kevin,
>> >It sounds like $HTTP_FORM_VARS['doQuickZoom'] is not being set.
>> >Add this:
>> >echo '<pre>';
>> >print_r( $HTTP_FORM_VARS );
>> >echo '</pre>';
>> >just before the if statement and send me the output for both an intial
>> page
>> >load and quickzoom page load. This will tell us exactly what is being
>> set
>> >(or not set ;) ).
>> >Regards,
>> >Bill
>> >> From: Kevin Grootendorst [mailto:kgrootendorst at BAIRD.COM]
>> >> Sent: January 26, 2005 3:12 PM
>> >> To: MAPSERVER-USERS at LISTS.UMN.EDU; William Bronsema
>> >> Subject: Re: Zoom to custom extent - PHP
>> >> Bill,
>> >> OK. This makes sense.
>> >> But, using the following statement:
>> >> If ( isset( $HTTP_FORM_VARS['doQuickZoom']) && $HTTP_FORM_VARS
>> >> ['doQuickZoom'] == "1" )
>> >> This returns a false, and the QuickZoom php code is not executed.
>> >> Using this statement:
>> >> ['doQuickZoom'] == "" )
>> >> Also returns a false.
>> >> If ($HTTP_FORM_VARS['doQuickZoom'] == "")
>> >> Returns a TRUE - and the php code is executed. But the map does not
>> draw
>> >> to the desired extents. It just refreshes the current map extent.
>> >> Thanks.
>> >> Kevin
>> >> On Wed, 26 Jan 2005 14:52:35 -0500, William Bronsema
>> >> >Kevin,
>> >> >doQuickZoom is supposed to go back to "". echo
>> >> >$HTTP_FORM_VARS['doQuickZoom'] before your "If ( isset(
>> >> >$HTTP_FORM_VARS['doQuickZoom'])...." statement to see what I mean.
It
>> >> >should only echo 1 after a quick zoom is called. You only want it to
>> be
>> >> 1
>> >> >when you want to do a quick zoom. Make sense?
>> >> >Is the PHP code being called to perform the quick zoom and the map is
>> >> just
>> >> >not zooming? Or is the PHP code not being called?
>> >> >Regards,
>> >> >Bill
