[OT] access DBF files via ODBC  (Linux)
    Wim Blanken
    w.blanken at GEON.NL
    Wed Jun  1 04:16:42 PDT 2005
Dag Bart,
I have searched for a specific dbf/xbase/clipper driver for or iodbc of
unixodbc in the recent past. Could not come up with a solution for this
question. I then used the program dbtcp to connect from linux to a windows
server that had the odbc configured. This worked OK for me in a specific
project. It's a so-called odbc-bridge but I do not think this is the answer
to your question.....so maybe anyone else has a better idea?
Groetjes!
Wim Blanken
GEON bv in Groningen
----- Original Message -----
From: "Bart van den Eijnden" <BEN at SYNCERA-ITSOLUTIONS.NL>
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Wednesday, June 01, 2005 9:56 AM
Subject: [UMN_MAPSERVER-USERS] [OT] access DBF files via ODBC (Linux)
> Hi list,
> does anybody know how to connect to DBF files via ODBC on Linux like Frank
> suggested in his e-mail below? Is there an ODBC DBF driver for Linux?
> Thanks in advance.
> Best regards,
> Bart
> Syncera-ITSolutions
> Postbus 270
> 2600 AG  DELFT
> tel.nr.: 015-7512436
> email: BEN at Syncera-ITSolutions.nl
>>>> fwarmerdam at gmail.com 05/04/05 06:03pm >>>
> On 5/4/05, Bart van den Eijnden <BEN at syncera-itsolutions.nl> wrote:
>> Hi Frank,
>> this thread reminded me of a question I wanted to ask, is there a similar
>> way to connect to DBF files with additional attribute information using
>> OGR? Which works both on Windows and Linux? Or would that require a new
>> driver?
> Bart,
> OGR's Shapefile driver already supports accessing "bare" .dbf
> files with no .shp or .shx file.  So the shapefile driver is a "free"
> dbf driver as well. Though limited to the relatively old and simple
> style of .dbf normally used with shapefiles.
> DBF files can be access directly by name or as a directory.
> You can also access DBF files via ODBC of course.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
More information about the MapServer-users
