Getting MapServer working (PHP MapScript)
Abe Gillespie
abe.gillespie at GMAIL.COM
Wed Jun 1 13:40:41 EDT 2005
I never see "didn't die." :( Also, I've tried turning on every
option for logging that I can think of and am getting nothing. I've
turned on everything in Apache and thumbed through php.ini and turned
on everything I could find there. Nothing.
On 5/31/05, Camden Daily <cdaily at gmail.com> wrote:
> This code is an example of how to use the builtin mapserver error
> messages. If the script actually DIES on the ms_newMapObj and doesn't
> run anything after that, then you need to look into PHP error
> messages.
> ms_ResetErrorList();
> dl("php_mapscript.so");
> $map = ms_newMapObj("simple.map");
> echo "didn't die";
> $img = $map->draw();
> $error = ms_GetErrorObj();
> while($error AND $error->code != MS_NOERR) {
> printf("Error in %s: %s<br>\n", $error->routine, $error->message);
> $error = $error->next();
