joining shp and dbase files
Alberto Gomez
agomez at CCCMM.CESGA.ES
Thu Jun 2 09:14:45 EDT 2005
Hi all,
I'm here again. I was working in localhost and it was right, but when i
tried access from internet i got this error:
msOGRFileOpen(): OGR error. ExecuteSQL(SELECT fshape.*,fdbf.* FROM POLIGONOS
fshape LEFT JOIN 'z:/GIS/ESZBAT.DBF'.ESZBAT fdbf ON fshape.POLIGONO =
fdbf.POLIGONO) failed. Unable to open secondary datasource
`z:/GIS/ESZBAT.DBF' required by JOIN.
I have tried with "//server/gis..." but it no works. It seems to be a
privileges problem as Emil advised me and I've tried to change in IIS the
IUSR_SERVER to access anonymously by a user who belongs to my domain, even
with admin privileges, but with any result. What about folder permissions?
Any ideas?
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Thursday, May 26, 2005 1:42 PM
Subject: Re: [UMN_MAPSERVER-USERS] joining shp and dbase files
> Hello Alberto,
> You could try switching to absolute path names.
> If your dbf is located at C:/inetpub/wwwroot/project/data/myfile.dbf
> Then instead of:
> "/inetpub/wwwroot/project/data/myfile.dbf"
> in the DATA parameter use:
> "C:/inetpub/wwwroot/project/data/myfile.dbf"
> Similair if the file is located at Z:/geodata/dbase/myfile.dbf
> "Z:/geodata/dbase/myfile.dbf"
> UNC paths also works so if your Z: disk is a mapping to a machine called
> alberto then use
> "\\alberto\geodata\dbase\myfile.dbf"
> Make sure the Windows user has appropriate rights to access the disk or
> share and don't forget that Windows IIS uses the IUSR on default.
> The IUSR account is a local machine account so it can only access local
> files and not mapped drives or other servers.
> So if you want to access data on other servers you need to switch to use a
> domain user in IIS (best is to create a new user or group for this
purpose).
> Accessing other drives/servers may work if you use integrated security in
> addition to anonymous access on IIS but this is only so if your (domain)
> accoutn has sufficient rights. Everybody from outside (not a domain user)
> will not be able to access that data. This can be confusing when testing
> your setup.
> Regards,
> Emil
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
> Behalf Of Alberto Gomez
> Sent: donderdag 26 mei 2005 13:31
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Hi Emil,
> Thank you for your quick response. It works great!!... but in local.
I'm
> working in windows and my dbf file is located in a network volume (Z:). I
> set DATA parameter with a full path like this:
> "/inetpub/wwwroot/project/data/myfile.dbf" and i need to change from "C:"
> to
> "Z:".
> Could you helpme with that?
> Tanks in advance,
> Alberto
> Texto añadido por Panda Client Shield:
> Este mensaje NO ha sido clasificado como SPAM. Si se trata de un mensaje
de correo no solicitado (SPAM), haz clic en el siguiente vínculo para
reclasificarlo: http://127.0.0.1:6083/Panda?ID=pav_1817&SPAM=true
