problem with tile index files and shape files
Emilio Mayorga
emiliom at U.WASHINGTON.EDU
Thu Jun 2 17:15:40 EDT 2005
I used ogrtindex to create a tile index file for a set of 7 polygon
shape files. These files (land cover types in country tiles) were
supposed to be identical in structure, but one of them is slightly
different, and that's the only one that Mapserver doesn't display when I
use a layer that refers to the tile index. If I refer to that deviant
shape file directly in a separate layer, with everything else the same
(I use FILTER expressions), it displays fine.
I'm using Mapserver 4.0 and OGR from October 2003 (I really need to
update one of these days...). Using ogrinfo on one of the good shape
files, I get this summary info:
AREA_KM2: Real (12.6)
IDUNESCO: String (25.0)
DESCRIPCIO: String (75.0)
PAIS: String (15.0)
But on the bad shape tile I get:
IDUNESCO: String (16.0)
DESCRIPCIO: String (150.0)
AREA_KM2: Real (13.6)
PAIS: String (15.0)
Fields are in a different order, and are defined just slightly
differently (I'm using FILTERITEM "IDUNESCO" in my layer). Also, the bad
shape file is grouping lots of polygons into few multipolygons, while
the other shape files seem to have individual polygons. (ogrinfo gives
"Geometry: Polygon" for both, though).
Can anyone suggest a way to tweak the bad shape file so it plays nice
with MapServer tile indices?
Thanks!
-Emilio Mayorga
