MapServer & PostGIS won't work..
Robert Campbell
rrc124 at GMAIL.COM
Thu Jun 2 21:55:25 PDT 2005
I just installed Postgres 8.0 and PostGIS 1.0.1 Win32 binaries. Both
work; I have a nice demo table set up with geometry columns, queries
work okay through pgAdmin III, etc.
I also installed MapServer for Windows - MS4W Base Install 1.1 which
is also working just fine (I'm able to run the tutorial pages and
modify the MapFiles, etc).
My problem is that when I add a postgis layer to a MapFile, nothing is
displayed. I went through the MapServer/PostGIS Wiki on
troubleshooting and I passed every test. I have included below my test
MapFile (the states layer displays perfectly):
MAP
IMAGETYPE PNG
EXTENT 201621.496941 -294488.285333 1425518.020722 498254.511514
SIZE 400 300
SHAPEPATH "data"
IMAGECOLOR 255 255 255
PROJECTION
"proj=laea"
"ellps=clrk66"
"lat_0=45"
"lon_0=-100"
# Alternatively, you can specify an EPSG code.
# "init=epsg:2163"
END
# Start of LAYER DEFINITIONS ---------------------------------------------
LAYER # States polygon layer begins here
NAME states
DATA states_ugl
STATUS DEFAULT
TYPE POLYGON
PROJECTION
"init=epsg:4326"
END
CLASS
COLOR 232 232 232
OUTLINECOLOR 32 32 32
END
END # States polygon layer ends here
LAYER
CONNECTIONTYPE postgis
NAME test
# Connect to a remote spatial database
CONNECTION "user=postgres dbname=GISage host=localhost"
# Get the lines from the 'geom' column of the 'roads' table
DATA "geom from gtest"
STATUS ON
PROJECTION
"init=epsg:4326"
END
TYPE LINE
# Of the lines in the extents, only render the wide highways
CLASS
# All the rest are darker and only 1 pixel wide
COLOR 255 22 22
SIZE 2
END
END
# End of LAYER DEFINITIONS -------------------------------
END # end of map file/object
While my table looks like:
SELECT id, name, AsText(geom) AS geom FROM gtest;
Results in:
id;name;geom
"1";"First Geometry";"LINESTRING(2 3,4 5,6 5,7 8)"
"2";"Second Geometry";"LINESTRING(202621 -194488,502621 -94488,801621
294488,1101621 394488)"
"3";"Third Geometry";"LINESTRING(45 -100,30 -80,20 -60,-20 50)"
Thanks everyone! Oh, and I was able to log in with psql using the two
above CONNECTION string details (postgres & localhost).
More information about the MapServer-users
