Simple question about scalebar.
Krung Saengpole
saengpole at YAHOO.COM
Fri Jun 3 01:42:29 EDT 2005
Thank you, it works now.
Dirk-Jan Huisman <d.huisman at INGBCC.NL> wrote:Hi,
The units of the projection is m. The Extent of your mapfile are m? If it is, the units of the mapfile should be m.
best regards
-----Oorspronkelijk bericht-----
Van: Krung Saengpole [mailto:saengpole at yahoo.com]
Verzonden: dinsdag 31 mei 2005 20:12
Aan: Dirk-Jan Huisman; mapserver-users at lists.umn.edu
Onderwerp: Re: [UMN_MAPSERVER-USERS] Simple question about scalebar.
Thank you for your response. My map file is simple as below:
MAP
SHAPEPATH "d:\work\gis\kornburi\data\"
FONTSET "./fonts/fonts.list"
SYMBOLSET "./symbols/symbol.sym"
EXTENT 730000 1550000 935000 1750000
UNITS kilometers
SIZE 600 450
IMAGETYPE gif
TRANSPARENT on
SCALEBAR
POSITION ll
STATUS off
COLOR 255 0 255
IMAGECOLOR 255 255 0
UNITS KILOMETERS
INTERVALS 3
STYLE 0
END
PROJECTION
"proj=utm"
"zone=47"
"a=6377276.345"
"b=6356075.413"
"towgs84=209,818,290,0,0,0,0"
"units=m"
"no_defs"
END
LAYER
END
My problem is that scalebar showed wrong distance. Everything is ok but scalebar. I told you last message that true distance it should be 18.3 km but scalebar showed 18300 km. I thought if this number was correct, then the unit should be meter not kilometer.
It's not clear what goes wrong. Include some code of your mapfile. What are the map units and the scalebar units?
Van: Krung Saengpole [mailto:saengpole at YAHOO.COM]
Verzonden: maandag 30 mei 2005 16:34
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: [UMN_MAPSERVER-USERS] Simple question about scalebar.
Dear all,
Whether or not I embeded scalebar in map, it showed wrong distance, e.g. it should be 18.3 km but it showed 18300 km. Nontheless I use projection or not. What I have to specially set to get right scalebar?
TIA
Krung
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
Prins Mauritsstraat 17, Postbus 75, 4140 AB Leerdam
Telefoon (0345) 63 96 96, Fax (0345) 63 96 66,
E-mail post at ingbcc.nl
Internet www.ingbcc.nl
Deze e-mail en de eventuele bestanden die meegezonden zijn, zijn vertrouwelijk en alleen bedoeld voor het gebruik door de individu of instelling aan wie deze e-mail geadresseerd is. Als u deze e-mail onterecht ontvangen heeft wilt u het ons dan laten weten.
This e-mail and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this e-mail in error please notify the system manager.
Do You Yahoo!?
Yahoo! Small Business - Try our new Resources site!
Discover Yahoo!
Get on-the-go sports scores, stock quotes, news & more. Check it out!
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050602/687076c0/attachment.html
