perl shapeobj values
Lowell Filak
lfilak at MEDINACO.ORG
Fri Jun 3 14:02:01 EDT 2005
The following message was sent by Simpson <asimpson at I-55.COM> on Fri, 3
Jun 2005 12:42:48 -0500.
> It looks like its of data type 'character' in the documentation at
> http://mapserver.gis.umn.edu/doc40/perlmapscript-reference.html and at
> http://mapserver.gis.umn.edu/doc44/swigmapscript-reference.html
> Is the shapeObj->{values} in Perl not the same as the one in PHP?
> Thanks,
> Drew.
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
> Behalf Of Simpson
> Sent: Friday, June 03, 2005 9:36 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] perl shapeobj values
> There is a shapeObj 'values' attribute in documentation at
> http://mapserver.gis.umn.edu/doc44/phpmapscript-class-guide.html#ShapeObj
> Drew.
> Behalf Of Eric Bridger
> Sent: Friday, June 03, 2005 6:10 AM
> No ''values' attribute of a shapeObj is exposed in the SWIG Mapscript API.
> Just numvalues and the getValue method.
> See: http://zcologia.com/mapserver/mapscript#shapeobj
> At 04:11 AM 06/03/2005 -0500, Simpson wrote:
> >Thanks, this very nice example will get the job done.
> >Out of curiosity, how would one use the 'values' attribute of shapeObj.
> >I saw lots of PHP examples like $shape->values["Population"].
> >Dumper($shape->{values}) was giving me something cryptic like "\bless( do
> >{...},'_p2p_..')".
> >The server for this project has Mapserver 4.01 and the layers are
from SDE.
> >Thanks again,
> >Drew.
> >From: Eric Bridger [mailto:eric at gomoos.org]
> >Sent: Thursday, June 02, 2005 9:25 PM
> >To: Simpson; MAPSERVER-USERS at lists.umn.edu
> >At 07:51 PM 06/02/2005 -0500, Simpson wrote:
> >>Hello,
> >>Could someone please tell me how to use the values attribute of shapeObj
> in
> >>Perl.
> >>I saw lots of examples in PHP, but no Perls.
> >>Thanks,
> >>Drew.
> >Here's some perl code.
> >if ( !$layerObj->queryByPoint( $map, $click, $mapscript::MS_MULTIPLE,
0 ) )
> > my $rslts = $layerObj->getResults();
> > if ($rslts)
> > for (my $i = 0; $i < $rslts->{numresults}; $i++)
> > my $rslt = $layerObj->getResult($i);
> > my $qid = undef;
> > $qid = $rslt->{shapeindex};
> > my $tid = $rslt->{tileindex};
> > $layerObj->open();
> > my $qshape = $layerObj->getFeature($qid, $tid);
> > if($qshape)
> > for(my $i = 0; $i < $qshape->{numvalues}; $i++)
> > my $val = $qshape->getValue($i);
> > my $col = $layerObj->getItem($i);
> > # do something with them.
> > $layerObj->close();
> > }# end for results
> > } # end if queryByPoint
> >See also: http://zcologia.com/mapserver/querying-howto
Drew,
That may be my bad. Because there are much better ways to retrieve the
field names and values from the shape I probably should not have even
mentioned the 'values' member in the documentation.
For me 'values' comes back blank and could mean it requires a swig
typemap just to work correctly.
Lowell
