time series representations in Mapserver
Gerry Creager N5JXS
gerry.creager at TAMU.EDU
Fri Jun 3 19:33:56 EDT 2005
A combination of user interface and cartography. I don't want to
reinvent the UI wheel, so to speak. We use a PostGIS database, so
timestamps are available already; backend should be OK.
Cartographically speaking, do we attempt this with Flash, or is the
timeseries WMS stuff ready for prime time?
Thanks!
gerry
Moran Ben-David wrote:
> Are you looking for advice on designing the User Interface for selecting
> datasets? Or are you looking for a way to implement the backend (e.g.
> database) time sensitive datasets and thematic shadings on maps? Or are you
> looking to create maps that exhibit change across time?
> i.e. my question is.. is your problem a user interface design, programming
> or cartography one?
> Moran Ben-David
> www.place-base.com
>>-----Original Message-----
>>From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
>>Behalf Of Gerry Creager N5JXS
>>Sent: Friday, June 03, 2005 2:12 PM
>>To: MAPSERVER-USERS at LISTS.UMN.EDU
>>Subject: [UMN_MAPSERVER-USERS] time series representations in Mapserver
>>We're looking at several applications where we need some time-selection
>>capabilities. Has anyone done this successfully with Mapserver, and if
>>so, might you share some tips?
>>TIA,gerry
>>Gerry Creager -- gerry.creager at tamu.edu
>>Texas Mesonet -- AATLT, Texas A&M University
>>Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.847.8578
>>Page: 979.228.0173
>>Office: 903A Eller Bldg, TAMU, College Station, TX 77843
Page: 979.228.0173
