displaying xy coordinates from database
Geoff Rowland
geoffrey.rowland at NOAA.GOV
Mon Jun 13 13:05:35 EDT 2005
Here is the code I use (using phpmapscript with MySQL)....this example
assumes that the coords stored in the database are pixels. There is
probably a better way to do it, but this works.
//Convert pixels to map units
function pix2geo($click_x, $click_y) {
global $map;
$e= &$map->extent; //for saving writing
$x_pct = ($click_x / $map->width);
$y_pct = 1 - ($click_y / $map->height);
$x_map = $e->minx + ( ($e->maxx - $e->minx) * $x_pct);
$y_map = $e->miny + ( ($e->maxy - $e->miny) * $y_pct);
return array($x_map, $y_map);
$sql = "SELECT x,y,city FROM my_table'";
$result = mysql_query($sql, $linkID);
//Draw the map and get the point layer
$img = $map->draw();
//MYPOINTS is the name of the point layer in the .MAP file
$layer = $map->getLayerByName('MYPOINTS');
for ($j=0; $j < mysql_num_rows($result); $j++)
$row = mysql_fetch_assoc($result);
// convert pixels to geocoded location
$map_pt = pix2geo($row[x],$row[y],$map->extent);
//Create the point
$pt = "pt" . $j;
//create dynamic variables based on num of mysql rows returned
${$pt} = ms_newPointObj();
${$pt}->setXY($map_pt[0],$map_pt[1]);
${$pt}->draw($map, $layer, $img, 0 ,$row[city]);
//draw the labels
$map->drawLabelCache($img);
//save image to disk - can specify name later
$url = $img->saveWebImage();
Cheers,
Geoff
Jessica Deegan wrote:
>Greetings list,
>A newbie to PHP/Mapscript, I am trying to display XY coordinates from a
>selected set of points (the XY to be displayed are a different location from
>selected point).
>As a test, I was successful in adding a dynamic point where a user clicks on
>the map using the sample found at
>http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapScriptAddPoint , but I'm
>at a loss to where to begin this process from a database perspective. My
>data are stored in a PostgreSQL database.
>Any suggestions or starting points would be highly appreciated.
>thanks,
>Jessica
Geoffrey Rowland
Technical Officer
Climate Information Project
NOAA Research
Office of Global Programs
http://www.cip.ogp.noaa.gov
Contractor,
RGII Technologies, Inc., a Computer Horizons Company
http://www.rg2.com
Phone: 301-427-2344
Fax : 301-427-2082
geoffrey.rowland at noaa.gov
