GeoTIFF overviews / TILEINDEX / Large dataset performance
Frank Warmerdam
fwarmerdam at GMAIL.COM
Mon Jun 13 20:40:19 PDT 2005
On 6/13/05, Ed McNierney <ed at topozone.com> wrote:
> There is a separate, independent effect due to the resampling of the
> source data. It is more expensive to resample an image ("zoom out" on
> it) than to display it at "native" resolution. So to create the most
> efficient source data for any given map request, you would (ideally)
> read as few files as possible AND resample each file as little as
> possible.
Ed,
This is true, but this effect is reduced by building "in image" overviews
since the required resolution of image data may be approximately available.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
More information about the MapServer-users
