GeoTIFF overviews / TILEINDEX / Large dataset performance
Ed McNierney
ed at TOPOZONE.COM
Tue Jun 14 07:48:14 EDT 2005
Frank -
Yes - that's certainly true. But I didn't think there was a substantial
difference between a single layer of TIFFs with in-image overviews vs. a
GROUP of layers with MINSCALE/MAXSCALE controls, each layer being an
independent set of resampled TIFFs.
The most important point, of course, is to minimize both the number of
files opened/read and the amount of resampling required for each
request. Thanks for the help!
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
Phone: +1 (978) 251-4242
Fax: +1 (978) 251-1396
ed at topozone.com
-----Original Message-----
From: Frank Warmerdam [mailto:fwarmerdam at gmail.com]
Sent: Monday, June 13, 2005 11:40 PM
To: Ed McNierney
Cc: MAPSERVER-USERS at lists.umn.edu
Subject: Re: [UMN_MAPSERVER-USERS] GeoTIFF overviews / TILEINDEX / Large
dataset performance
On 6/13/05, Ed McNierney <ed at topozone.com> wrote:
> There is a separate, independent effect due to the resampling of the
> source data. It is more expensive to resample an image ("zoom out" on
> it) than to display it at "native" resolution. So to create the most
> efficient source data for any given map request, you would (ideally)
> read as few files as possible AND resample each file as little as
> possible.
Ed,
This is true, but this effect is reduced by building "in image"
overviews since the required resolution of image data may be
approximately available.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | Geospatial Programmer for Rent
