EPSG code for...
Christopher R. Thorne
christhorne at SYMPATICO.CA
Tue Jun 14 10:36:45 EDT 2005
Hello me again,
I finally tracked down the metadata for the data that was given to me
with the strange projection. Well it gets stranger. Here is what I
found. I have two shape files of the Los Angeles county
1st shape file :
Datum:NAD27
Units: Meters
Ellipsoid:Clark 1866
Projection: UTM, Zone 11
* Possible EPSG codes found:
# NAD27(76) / MTM zone 11
<2020> +proj=tmerc +lat_0=0 +lon_0=-82.5 +k=0.999900 +x_0=304800 +y_0=0
+ellps=clrk66 +units=m +no_defs no_defs <>
# NAD27 / UTM zone 11N
<26711> +proj=utm +zone=11 +ellps=clrk66 +datum=NAD27 +units=m +no_defs
no_defs <>
2nd shape file:
Datum:NAD83
Units: Meters
* Possible EPSG Codes found:
NONE FOUND.....
This makes me think that NAD83 with a Clark 1866 Ellipsoid is not a
valid projection. Am I on the right trake of thinking or is there
actually an EPSG code with:
<????> +proj=utm +zone=11 +ellps=clrk66 +datum=NAD83 +units=m +no_defs
no_defs <>
Comments?
Chris
Christopher R. Thorne wrote:
> Hello Dean,
> Dean C. Mikkelsen wrote:
>> Hi Chris,
>> Take a look at the following web-page.
>> I am leaning towards a problem now in defining which State Plane
>> Co-ordinate System is being used. i.e. one of the ones we are using is
>> wrong - we may actually be north or south of the current one. Now the
>> trick is to determine which one. A note to other readers epsg:4326 is
>> WGS84.
>> Did you try reprojecting the NAD27 Layer with the NAD83 definition?
> Yes I did that and the layers switched positions.
> Or
>> with epsg:4326? What happens?
> with setting the projection to the lat/long layers, they are not found
> in outer space, not within the world extent.
>> http://www.wadetrim.com/resources/articles/sblocks.htm
> Thanks for the good reference. The reason why I got into this situation
> was because I am four steps removed from the data provider. I only
> managed to get the information that you already know and I was hoping
> the information was correct. The other problem was that I was not sure
> how to identify the issues, confidently. If not I will definitely push
> for more information.
> Cheers and thanks again,
> Chris
Christopher R. Thorne, GIS Specialist
christhorne at sympatico.ca
Tel:(613)523-6593, Ottawa ON Canada
