EPSG code for...
Dean Mikkelsen dcmikkelsen at SHAW.CA
Tue Jun 14 09:10:03 PDT 2005
Hi again,
MTM is defined for Canada. They are 3 degree Modified Transverse Mercator projections. They will not apply to Canada.
For a reference see the following web-sites:
MTM:
http://www.geod.nrcan.gc.ca/images/products/MTM.jpg
UTM:
http://www.geod.nrcan.gc.ca/images/products/UTM.jpg
Both were referred to via:
http://www.geod.nrcan.gc.ca/index_e/online_apps_e/appNtv2_e/appntv2_utm_e.html
Cheers,
Dean
----- Original Message -----
From: "Christopher R. Thorne" <christhorne at SYMPATICO.CA>
Date: Tuesday, June 14, 2005 7:36 am
Subject: Re: [UMN_MAPSERVER-USERS] EPSG code for...
> Hello me again,
> I finally tracked down the metadata for the data that was given to
> me
> with the strange projection. Well it gets stranger. Here is what I
> found. I have two shape files of the Los Angeles county
> 1st shape file :
> Datum:NAD27
> Units: Meters
> Ellipsoid:Clark 1866
> Projection: UTM, Zone 11
>  * Possible EPSG codes found:
> # NAD27(76) / MTM zone 11
> <2020> +proj=tmerc +lat_0=0 +lon_0=-82.5 +k=0.999900 +x_0=304800
> +y_0=0
> +ellps=clrk66 +units=m +no_defs  no_defs <>
> # NAD27 / UTM zone 11N
> <26711> +proj=utm +zone=11 +ellps=clrk66 +datum=NAD27 +units=m
> +no_defs
>  no_defs <>
> 2nd shape file:
> Datum:NAD83
> Units: Meters
>   * Possible EPSG Codes found:
>   NONE FOUND.....
> This makes me think that NAD83 with a Clark 1866 Ellipsoid is not
> a
> valid projection. Am I on the right trake of thinking or is there
> actually an EPSG code with:
> <????> +proj=utm +zone=11 +ellps=clrk66 +datum=NAD83 +units=m
> +no_defs
> no_defs <>
> Comments?
> Chris
> Christopher R. Thorne wrote:
> > Hello Dean,
> > Dean C. Mikkelsen wrote:
> >> Hi Chris,
> >> Take a look at the following web-page.
> >> I am leaning towards a problem now in defining which State Plane
> >> Co-ordinate System is being used. i.e. one of the ones we are
> using is
> >> wrong - we may actually be north or south of the current one.
> Now the
> >> trick is to determine which one. A note to other readers
> epsg:4326 is
> >> WGS84.
> >> Did you try reprojecting the NAD27 Layer with the NAD83
> definition?
> > Yes I did that and the layers switched positions.
> > Or
> >> with epsg:4326? What happens?
> > with setting the projection to the lat/long layers, they are not
> found
> > in outer space, not within the world extent.
> >> http://www.wadetrim.com/resources/articles/sblocks.htm
> > Thanks for the good reference. The reason why I got into this
> situation
> > was because I am four steps removed from the data provider. I
> only
> > managed to get the information that you already know and I was
> hoping
> > the information was correct. The other problem was that I was
> not sure
> > how to identify the issues, confidently. If not I will
> definitely push
> > for more information.
> > Cheers and thanks again,
> > Chris
> Christopher R. Thorne, GIS Specialist
> christhorne at sympatico.ca
> Tel:(613)523-6593, Ottawa ON Canada
More information about the MapServer-users mailing list
