DEM Elevation data
Jerl Simpson
jerl.simpso at GMAIL.COM
Tue Jun 14 16:55:02 EDT 2005
Thank you sir,
I think this will help me out. I guess there is a way to convert
these to geotiff?
Thanks again,
jerl
On 6/14/05, William E Reid <wer at cstone.net> wrote:
> Just My 2 cents on the Subject.
> DEMs are no longer readily available from places like usgs. I am not
> really sure why. They are the easiest to work with (ie convert).
> If you are in the States....
> at http://seamless.usgs.org you can download 3arc and 1arc second
> terrain data. It comes in ArcGrid Format. Though I have not seen a way
> to do this, I will be looking to convert them to geotiffs and shape
> files and dems with less granularity.
> A geotiff loads quickly and gives the best performance in mapserver
> (from my experience anyway) if you are just looking to make things look
> more interesting.
> Actually, you can download the data in Geotiff format, which is what I
> would recommend.... These might be more then what you want for
> granularity, I only dealt with 3arc and above data.
> National Elevation Dataset. I love em.
> Your Tiff? Make sure it is a geotiff. It needs to know where it is on
> the map. If you disable TRANFORM (set it to false) in your layer it
> will probably show up. But it needs to be a geotiff to show up properly.
> Hope that helps.
> -=Bill
> Jerl Simpson wrote:
> > Hi guys,
> > I am wanting to add DEMs or some elevation/contour maps to my maps.
> > But I am curious what works best with Mapserver. I have found several
> > different resource, but am at a loss as to which one I need.
> > The first one I tried, which was to download JPEG images and convert
> > them to TIFF images, never actually show up as a layer. This may be a
> > format issue on my part. I haven't dug into that yet.
> > I found one that is a ETOPO2 Global 2-Minute Gridded Elevation Data.
> > But I don't know what that is and not sure if it can be used. If
> > someone knows a trick, I'd be please to find out.
> > Similar issue with GLOBE files from NOAA. Not sure if I can convert
> > them to a format that's useful to use with Mapserver.
> > I'm sure there are other options, I just haven't found them.
> > I appreciate any help anyone might be able to give.
> > Thank you,
> > Jerl
