Strange problem in a tileindex of shape files
luca marletta
lucamarle at GMAIL.COM
Tue Jun 14 14:21:19 PDT 2005
I found by myself at last. I post here for someone with silly as me.
I forgot
TEMPLATE void
in every CLASS section
bye
On 6/14/05, luca marletta <lucamarle at gmail.com> wrote:
> Sometimes technology is very odd! could someone give me a hint to
> discover my error?
> I did a tileindex (using ogrtindex) of several shp files with the same
> fields in dbf.
> All works well, here the map:
> LAYER
> NAME "incendi2002"
> STATUS ON
> TILEINDEX "/var/www/pmapper/comalo/incendi/incendi2002.shp"
> TILEITEM "Location"
> TYPE POLYGON
> TRANSPARENCY 60
> METADATA
> "DESCRIPTION" "Incendi 2002|Incendi 2002|Incendi 2002"
> "RESULT_FIELDS"
> "COMUNE,STZ_FOREST,INCEND2002,M_LGN_DIST,SUP_TOT_HA,SUP_BOS_HA,SUP_NOBOS"
> "RESULT_HEADERS" "Comune,Stazione forestale,N° incendi,???,Superfice
> (ha),Sup boscosa (ha),Sup non boscosa (ha)|Comune,Stazione
> forestale,N° incendi,???,Superfice (ha),Sup boscosa (ha),Sup non
> boscosa (ha)|Comune,Stazione forestale,N° incendi,???,Superfice
> (ha),Sup boscosa (ha),Sup non boscosa (ha)"
> END
> LABELITEM "COMUNE"
> CLASS
> NAME "1 incendio nel 2002|1 incendio nel 2002|1 incendio nel 2002"
> EXPRESSION ([INCEND2002] = 1)
> COLOR 255 225 225
> LABEL
> COLOR 0 0 255
> TYPE TRUETYPE
> FONT arial
> SIZE 10
> ANTIALIAS TRUE
> POSITION CL
> PARTIALS FALSE
> MINDISTANCE 300
> BUFFER 4
> END # end of label
> END
> CLASS
> NAME "2 incendi nel 2002|2 incendi nel 2002|2 incendi nel 2002"
> EXPRESSION ([INCEND2002] = 2)
> COLOR 255 175 175
> LABEL
> COLOR 0 0 255
> TYPE TRUETYPE
> FONT arial
> SIZE 10
> ANTIALIAS TRUE
> POSITION CL
> PARTIALS FALSE
> MINDISTANCE 300
> BUFFER 4
> END # end of label
> END
> CLASS
> NAME "3 incendi nel 2002|3 incendi nel 2002|3 incendi nel 2002"
> EXPRESSION ([INCEND2002] = 3)
> COLOR 255 145 145
> LABEL
> COLOR 0 0 255
> TYPE TRUETYPE
> FONT arial
> SIZE 10
> ANTIALIAS TRUE
> POSITION CL
> PARTIALS FALSE
> MINDISTANCE 300
> BUFFER 4
> END # end of label
> END
> CLASS
> NAME "4 incendi nel 2002|4 incendi nel 2002|4 incendi nel 2002"
> EXPRESSION ([INCEND2002] > 3)
> COLOR 255 85 81
> LABEL
> COLOR 0 0 255
> TYPE TRUETYPE
> FONT arial
> SIZE 10
> ANTIALIAS TRUE
> POSITION CL
> PARTIALS FALSE
> MINDISTANCE 300
> BUFFER 4
> END # end of label
> END
> END
> The strange fact is that when I did the layer in the map, it was
> minimal and all worked well also for the query (single and multiple).
> When later I developed the map to the shown code the query doesn't
> work anymore, or better, it doesn't find any layer there.
> I tried to get back step by step to the previous situation but I'm no
> more able to obtain a query from this layer.
> Could you help me please?
> thanks a lot
> luca
> luca marletta icq: 70590647
More information about the MapServer-users
