I need your idea
Simpson
asimpson at I-55.COM
Tue Jun 14 18:10:41 EDT 2005
I think the rectangle is what Mapserver zooms to within your extent.
414562,4617510 521317,4617510
0,0 400,0
0,406 400,406
414562,4510820 521317,4510820
So in the above example, to zoom to the full extent you'd need to set the
pixel extent rectangle to (0,406,400,0).
The satellite imagery may not fill the entire output image, since Mapserver
maintains aspect ratio.
Drew.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
Behalf Of orkun
Sent: Tuesday, June 14, 2005 3:38 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] I need your idea
hello
I need your idea
how can I show an satellite imagery in full extent when
you click in menu.
if you have time please look at :
"http://landslide.deprem.gov.tr/cgi/map4.php" and click in "satellite"
I just want it to fill whole map's window.
I used php-mapscript and here is the code fragment:
/$uydulayer->set("status",1); # on
$minx=414562.225;
$miny=4510820;
$maxx=521317.775;
$maxy=4617510;
$extent_to_set = explode(" ",$HTTP_POST_VARS["extent"]);
$map->setextent($extent_to_set[0],$extent_to_set[1],
$extent_to_set[2],$extent_to_set[3]);
$my_extent = ms_newrectObj();
$my_extent->setextent($extent_to_set[0],$extent_to_set[1],
$zoom_rect = ms_newRectObj();
$zoom_rect->setextent(200,203,200,203); //satellite imagery
pixel extents
$map->zoomrectangle($zoom_rect,$map->width,$map->height,$my_extent);
$extent_to_html = $minx." ".$miny." "
.$maxx." ".$maxy;
/I will appreciate if you give a sense/
/Ahmet Temiz
______________________________________
XamimeLT - installed on mailserver for domain @deprem.gov.tr
Queries to: postmaster at deprem.gov.tr
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake
Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak
T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte
degildir.
