Wfs filter
vincent.dacol
vincent.dacol at LAPOSTE.NET
Wed Jun 15 10:44:36 EDT 2005
Thanks for the answer Bart,
I have set Dump True in my WFS Mapserver.
I have try directly on the serveur as describe in the HOWTO,
but it didn't work.
I will try some other test tomorrow.
Bye,
Vincent
> Just checking, did you set DUMP TRUE on your server LAYER?
> Can you get it to work by making a HTTP GET request directly
to your server using the same Filter, something like which is
described in here:
> http://mapserver.gis.umn.edu/doc/filter-encoding-howto.html
> Best regards,
> Bart
> Bart van den Eijnden
> Syncera IT Solutions
> Postbus 270
> 2600 AG DELFT
> tel.nr.: 015-7512436
> email: BEN at Syncera-ITSolutions.nl
> >>> "vincent.dacol" <vincent.dacol at LAPOSTE.NET> 06/15/05
09:02am >>>
> Hi the list,
> I want to apply a filter on my WFS server.
> But this simple thinks seem harder than I think.
> The original data is a shape file with attribut and
> geographique data.
> The result of the filter is an empty GML file.
> Here is a copy of my WFS mapserver client and the GML file.
> Thanks for the help.
> Extract of WFS layer in the Client mapfile:
> CONNECTIONTYPE WFS
> CONNECTION
"http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/projection/Serveur_France/France_L93_WFS.map&"
> METADATA
> "wfs_service" "WFS"
> "wfs_version" "1.0.0"
> "wfs_typename" "France_L93_Name"
> "wfs_connectiontimeout" "120"
> "wfs_filter"
"<PropertyIsGreaterThan><PropertyName>PERIMETRE</PropertyName><Literal>300</Literal></PropertyIsGreaterThan>"
> END
> The GML data :
> <?xml version='1.0' encoding="ISO-8859-1" ?>
> <wfs:FeatureCollection
> xmlns="http://www.ttt.org/myns"
> xmlns:myns="http://www.ttt.org/myns"
> xmlns:wfs="http://www.opengis.net/wfs"
> xmlns:gml="http://www.opengis.net/gml"
> xmlns:ogc="http://www.opengis.net/ogc"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:schemaLocation="http://www.opengis.net/wfs
> http://schemas.opengeospatial.net/wfs/1.0.0/WFS-basic.xsd
http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/projection/Serveur_France/France_L93_WFS.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=DescribeFeatureType&TYPENAME=France_L93_Name">
> <gml:boundedBy>
> <gml:null>missing</gml:null>
> </gml:boundedBy>
> </wfs:FeatureCollection>
> Bye,
> Vincent
> Accédez au courrier électronique de La Poste :
www.laposte.net ;
> 3615 LAPOSTENET (0,34/mn) ; tél : 08 92 68 13 50 (0,34/mn)
Accédez au courrier électronique de La Poste : www.laposte.net ;
