Catching error of getShape - php_mapscript
Jacob Delfos jacob.delfos at MAUNSELL.COM
Thu Jun 16 00:04:32 PDT 2005
Hi all,
Can anyone tell me if there is a way to catch the error that getShape throws if you request a shape that is out of range?
Reason is I'm trying to iterate through a layer. At this stage, I need to use an object count to make the loop stop. Getting an object count either requires me to use the shpfileobj->numshapes variable (which obviously only works on shapefiles), or doing a query (which would only work on layers with templates, which would need a reprojected rectangle, uses overhead, etc..).
Would it be possible to make getShape return MS_FAILURE if the object is out of range, or throw a warning that can be caught using '@' error suppression? That way one could iterate through a whole layer without needing a layer count.
Regards,
Jacob
JACOB DELFOS
SPATIAL INFORMATION ANALYST
Maunsell Australia Pty Ltd
629 Newcastle Street, Leederville, WA 6007
PO Box 81, Leederville, WA 6902
Western Australia
ABN 20 093 846 925
Tel     + 61 8 9281 6185
Fax    + 61 8 9281 6297
jacob.delfos at maunsell.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050616/f02115cf/attachment.htm>
More information about the MapServer-users mailing list
