DBox PHP Problems
Piero Cavalieri
piero.cavalieri at HEIDI.IT
Mon Jun 20 06:13:51 EDT 2005
Is the form name set to main_map ?
Also I had problems with the DHTML library includes (don't know why) and I
solved using another path: src="javascript/x/x_core.js" ecc..
Piero
Rob McCulley wrote:
>I would like to use DBox with PHP-mpscript, but I'm having some problems
>figureing out how to implement it. I currently have it set up like so:
>--- A bunch of PHP that sets up map size and layers ---
> <!-- Step 1: dBox library include -->
> <script language="JavaScript" src="javascript/dbox.js"></script>
> <!-- Step 2: DHTML library includes -->
>src="javascript/cross-browser.com/x/x_core.js"></script>
>src="javascript/cross-browser.com/x/x_event.js"></script>
>src="javascript/cross-browser.com/x/x_dom.js"></script>
>src="javascript/cross-browser.com/x/x_drag.js"></script>
src="javascript/jsgraphics.js"></script>
> <SCRIPT LANGUAGE="JavaScript">
> // Step 3: Create the dBox object (initialize a few things)
> var main_map = new dBox("main_map", <?php echo $map_height; ?>,
><?php echo $map_width; ?>, "#FF0000", 2);
> main_map.box = true;
> function setbox_handler(name, minx, miny, maxx, maxy) {
> document.map_app.imgbox.value = minx + " " + miny + " " + maxx
>+ " " + maxy;
> document.map_app.imgxy.value = minx + " " + miny;
> document.map_app.submit();
> function seterror_handler(message) {
> alert(message);
> function reset_handler(name, minx, miny, maxx, maxy) { }
> function startup() {
> // Step 4: Initialize the dBox object
> main_map.initialize();
> </SCRIPT>
>--- A bunch of PHP that generates the map and legend ---
> <!--Display the Map -->
> <!-- this is the holding spot (the anchor) for the map -->
> <DIV id="main_map_anchor" style="position:relative;
>visibility:visible; width:100%; height:100%; left:0px; top:0px;">
> <IMG src="pixel.gif" height="<?php echo $map_height; ?>"
>width="<?php echo $map_width; ?>">
> </DIV>
> <!-- absolutely positioned layer to hold the map -->
> <DIV id="main_map" style="position:absolute; visibility:visible;
>width:100%; height:100%; clip:rect(100%,100%,100%,100%);
>background:transparent;">
> <IMG name="main_map" src="<?php echo $image_url; ?>"
>height="<?php echo $map_height; ?>" width="<?php echo $map_width; ?>">
> </DIV>
>My zoom tools are setup like so:
> <input type=radio name=zoomdir value=1
>onClick="main_map.boxon();">Zoom In<BR>
> <input type=radio name=zoomdir value=0
>onClick="main_map.boxoff();">Pan<BR>
> <input type=radio name=zoomdir value=-1
>onClick="main_map.boxoff();">Zoom Out<BR>
>Two problems - the first is that the map isn't visible. I'm assuming it
has
>to do with the div boxes and the transparent pixels. Not my main problem,
>I'm sure I can solve it. The main problem is that when I click on the zoom
>in radio button (or any of the three radio buttons for that matter) I get a
>javascript error "Object doesn't support property or method" pointing at
the
>line of code for the radio button.
>Any ideas what I'm doing wrong? Or does anyone have an example of DBox
>working with PHP that they can point me at?
>Thank You,
>Rob McCulley
>GIS Coordinator
>County of Vermilion River No. 24
>(780) 846-2244
>RMcCulley at County24.com
