java mapscript error
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Tue Jun 21 04:51:28 EDT 2005
Note: I have just downloaded mapserver 4.6 and it compiles fine and
tests run out of the box, so it is not a problem with mapserver.
Can you confirm there is a libmapscript.so in mapscript/java ?
Post the java version ( java -version ) output.
Regards,
Umberto
On 6/20/05, orkun <temiz at deprem.gov.tr> wrote:
> (sorry if it is sent twice)
> thank you again
> $ make test
> javac -classpath ./:examples/:./mapscript.jar -d examples/ examples/*.java
> java -classpath ./:examples/:./mapscript.jar -Djava.library.path=.
> DumpShp ../../tests/point.shp
> java.lang.UnsatisfiedLinkError: no mapscript in java.library.path
> make: *** [test] Error 255
> regards
> ______________________________________
> XamimeLT - installed on mailserver for domain @deprem.gov.tr
> Queries to: postmaster at deprem.gov.tr
> The views and opinions expressed in this e-mail message are the sender's own
> and do not necessarily represent the views and the opinions of Earthquake Research Dept.
> of General Directorate of Disaster Affairs.
> Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
> B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
