mapscript/java errors
orkun
temiz at DEPREM.GOV.TR
Mon Jun 20 07:56:52 EDT 2005
Umberto Nicoletti wrote:
>you should find a libmapscript.so in mapscript/java.
>Try to run the tests with
>make test
>Regards,
>Umberto
>>>You need to compile mapserver first and then cd to mapscript/java. You
>>>should try to run
>>>make interface
>>>before running make in mapscript/java as it will generate/update the
>>>swig-generated interface files. You need a very recent version of swig
>>>to run make interface.
>>>I have not tried mapserver 4.6 yet so there might be unresolved issues
>>>with java maspcript that I am not aware of.
>>>HTH,
>>>Umberto
>>>>thank you for your interest:
>>>>- linux debian testing
>>>>- mapserver-4.6.0-beta1
>>>>- I changed mapscript/java then entered make and the nightmare started.
>>>>here is my config
>>>>--with-proj \
>>>>--with-threads \
>>>>--with-ogr \
>>>>--with-gd=/usr/local/gd-2.0.33 \
>>>>--with-gdal=/usr/local/bin/gdal-config \
>>>>--with-png \
>>>>--with-php=/usr/local/php-5.0.4/ \
>>>>--with-java=/usr/local/jdk1.5.0_03/
>>>>I have been using phpmapscript. But I am curious about java.
>>>>Can you say that developing and using mapserver with java is better
>>>>than php ?
>>>>regards
>>>>______________________________________
>>>>XamimeLT - installed on mailserver for domain @deprem.gov.tr
>>>>Queries to: postmaster at deprem.gov.tr
>>>>The views and opinions expressed in this e-mail message are the sender's own
>>>>and do not necessarily represent the views and the opinions of Earthquake Research Dept.
>>>>of General Directorate of Disaster Affairs.
>>>>Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
>>>>B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
>>hello
>>with make interface, it produced so many *.java files in
>>../mapscript/java/edu/umn/gis/mapscript/ directory.
>>not a compiled library as in phpmapscript.so ?
>>Is there anything as next step ?
>>regards
>>Ahmet
thank you again
$ make test
javac -classpath ./:examples/:./mapscript.jar -d examples/ examples/*.java
java -classpath ./:examples/:./mapscript.jar -Djava.library.path=.
DumpShp ../../tests/point.shp
java.lang.UnsatisfiedLinkError: no mapscript in java.library.path
make: *** [test] Error 255
regards
