LatLongBoundingBox problem with WFS server
Etienne Dube
etdube at GMAIL.COM
Tue Jun 21 09:19:13 EDT 2005
Hello,
I'm trying to use MapServer as a WFS server, pulling data from a PostGIS
DB. My original data is not projected, it's in geographic coordinates
(lat/long) in the NAD83 datum. When I use the GET method to issue a
'getcapabilities' request it displays the XML file, but I get weird
bounding box coordinates :
<LatLongBoundingBox minx="-2.5e+007" miny="-2.5e+007" maxx="2.5e+007"
maxy="2.5e+007"/>
The extent defined in my MAP file is -69.2 45.0 -33.2 48.2 (in decimal
degrees). When I try to open the WFS layer in uDig, I can't see
anything, uDig seems to be confused by the wrong numbers in
LatLongBoundingBox (when I'm moving the mouse around in the map window,
it displays out of bound coordinates). On the other hand, when I issue a
'getfeature' request from a web browser, I get the right numbers for the
<gml:coordinates> tags :
<gml:coordinates>-69.588602,44.311578
-62.161745,48.794835</gml:coordinates>
Here is my MAP file :
NAME CRADWFS
STATUS ON
SIZE 400 300
SYMBOLSET ../etc/symbols.sym
EXTENT -69.200 45.000 -63.200 48.200
UNITS DD
IMAGECOLOR 255 255 255
FONTSET ../etc/fonts.txt
WEB
IMAGEPATH "/ms4w/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
METADATA
"wfs_title" "Test wfs craddata" ## REQUIRED
"wfs_onlineresource"
"http://localhost/cgi-bin/mapserv.exe?map=../../apps/gmap/htdocs/wfstest.map&"
## Recommended
"wfs_srs" "EPSG:4269" ## Recommended
END
END
PROJECTION
"init=epsg:4269"
END
LAYER
NAME maritimescd
METADATA
"wfs_title" "maritimescd" ## REQUIRED
END
TYPE POLYGON
STATUS ON
CONNECTIONTYPE POSTGIS
CONNECTION "dbname=craddata user=crad password=*******"
DATA "geom from tmp_maritimescd"
PROJECTION
"init=epsg:4269"
END
DUMP TRUE ## REQUIRED
CLASS
NAME "maritimescd"
COLOR 128 128 128
OUTLINECOLOR 0 0 0
END
END # Layer
END # Map File
Any ideas? Thanks,
Etienne
