Trouble with displaying projected shapefile
Hoeven, Maarten van der
Maarten.van.der.Hoeven at KNMI.NL
Tue Jun 21 15:09:18 EDT 2005
When you know what to look at, things are soooooo obvious. Thanks Ethan, the UNITS was wrong. It is working like a charm now.
Regards,
Maarten
-----Original Message-----
From: UMN MapServer Users List on behalf of Ethan Alpert
Sent: Tue 6/21/2005 7:45 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Trouble with displaying projected shapefile
Do you pass the layer name in the URL (&layers=world_eca)? The status of
your layer is ON this means it's only displayed if requested. Change it
to DEFAULT if you want it displayed regardless of whether you ask for
it. The only other thing I notice is that you pass Decimal Degrees
Extents but say the UNITS are METERS in your mapfile. I'm sure this is
being interpreted wrong. Do a shpdump on the shapfile and use the "File
Bounds" listed as your extents.
-e
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Hoeven, Maarten van
der
Sent: Tuesday, June 21, 2005 5:50 AM
Subject: [UMN_MAPSERVER-USERS] Trouble with displaying projected
shapefile
Dear list,
I have a shape file, world_eca, projected in "north pole
stereographic". Below are the projection specifications.
I added the shape file in the map, but I do not manage to
display it in mapserver. Is there something obvious I am doing wrong?
An "echo $gpoMap->getProjection()" reveals "+proj=stere
+lat_ts=90 +lat_0=90 +lon_0=0 +k_0=1 +x_0=0 +y_0=0"
Regards,
Maarten van der Hoeven
--- projection specs ---
PROJCS["North_Pole_Stereographic",
GEOGCS["GCS_WGS_1984",
DATUM["D_WGS_1984",
SPHEROID["WGS_1984",6378137.0,298.257223563]],
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.0174532925199433]],
PROJECTION["Stereographic"],
PARAMETER["False_Easting",0.0],
PARAMETER["False_Northing",0.0],
PARAMETER["Central_Meridian",0.0],
PARAMETER["Scale_Factor",1.0],
PARAMETER["Latitude_Of_Origin",90.0],
UNIT["Meter",1.0]]
--- map file ---
# Start of map file
NAME ECAD
STATUS ON
SIZE 400 300
SYMBOLSET ../etc/symbols.sym
EXTENT -90 0 90 90
UNITS meters
SHAPEPATH "../data"
IMAGECOLOR 255 255 255
FONTSET ../etc/fonts.txt
PROJECTION
"+proj=stere"
"+lat_ts=90"
"+lat_0=90"
"+lon_0=0"
"+k_0=1"
"+x_0=0"
"+y_0=0"
END
QUERYMAP
STATUS ON
STYLE SELECTED
COLOR 255 0 0
END
WEB
MINSCALE 2000
MAXSCALE 50000000
IMAGEPATH "/webdata/ecad/htdocs/tmp/"
IMAGEURL "/tmp/"
LOG /tmp/gmap.log
END
REFERENCE
IMAGE images/keymap.png
EXTENT -2200000 -712631 3072800 3840000
STATUS ON
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
SIZE 120 90
END
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
STATUS ON
END
SCALEBAR
LABEL
COLOR 0 0 0
SIZE SMALL
END
SIZE 350 5
COLOR 255 255 255
BACKGROUNDCOLOR 255 0 0
OUTLINECOLOR 0 0 0
UNITS kilometers
INTERVALS 10
STATUS ON
END
LAYER
NAME world_eca
PROJECTION
"+proj=stere"
"+lat_ts=90"
"+lat_0=90"
"+lon_0=0"
"+k_0=1"
"+x_0=0"
"+y_0=0"
END
TYPE POLYGON
STATUS ON
DATA world_eca
CLASS
STYLE
OUTLINECOLOR 100 100 100
COLOR 191 209 255
END
END
END
END # Map File
Drs. Maarten van der Hoeven
ECA&D Project
PO Box 201
3730 AE De Bilt
The Netherlands
Phone: +31-30-2206 402
Fax: +31-30-2204 614
Email: hoevenvd at knmi.nl (personal)
Email: eca at knmi.nl (project)
Website: http://eca.knmi.nl <http://eca.knmi.nl>
