java mapscript error
orkun
temiz at DEPREM.GOV.TR
Wed Jun 22 02:39:06 EDT 2005
Umberto Nicoletti wrote:
>Do you have the JAVA_HOME variable set?
>REGARDS,
>Umberto
>>>>I am sorry to take up your time
>>>>I made a fresh compilation without encountering any problem
>>>>till ./java/make.
>>>You have to be in mapscript/java directory when you run make!!!!
>> ./java is ./mapscript/java
>>>Execute the commands as I have written them (LITERALLY, you can copy
>>>and paste ) in my previous post. If still it does not work post the
>>>relevant parts of your shell history so I can see what you have done
>>>exactly.
>>>Do you have javac? Try running javac at the command prompt.
>>..../mapserver-4.6.0/mapscript/java$ javac -version
>>javac 1.5.0_03
>>>Regards,
>>>Umberto
>>>>there are so many errors in /mapserver-4.6.0/mapscript/java directory
>>>>when I enter make in this way:
>>I am sending error file in attachment.
>>regards
>>______________________________________
>>XamimeLT - installed on mailserver for domain @deprem.gov.tr
>>Queries to: postmaster at deprem.gov.tr
>>The views and opinions expressed in this e-mail message are the sender's own
>>and do not necessarily represent the views and the opinions of Earthquake Research Dept.
>>of General Directorate of Disaster Affairs.
>>Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
>>B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
>>gcc -fpic -c -O2 -fPIC -Wall -DIGNORE_MISSING_DATA -DNEED_STRLCAT -DUSE_EPPL -DUSE_PROJ -DUSE_WMS_SVR -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS -DUSE_OGR -DUSE_GDAL -DUSE_THREAD -I/usr/local/gd-2.0.33 -I/usr/local/include -I/include -I/include/linux -fno-strict-aliasing mapscript_wrap.c
>>mapscript_wrap.c:24:17: jni.h: No such file or directory
>>mapscript_wrap.c:48: error: parse error before '*' token
>>mapscript_wrap.c: In function `SWIG_JavaThrowException':
>>mapscript_wrap.c:49: error: `jclass' undeclared (first use in this function)
>>mapscript_wrap.c:49: error: (Each undeclared identifier is reported only once
>>mapscript_wrap.c:49: error: for each function it appears in.)
>>mapscript_wrap.c:49: error: parse error before "excep"
>>mapscript_wrap.c:63: error: `code' undeclared (first use in this function)
>>mapscript_wrap.c:66: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:67: error: `excep' undeclared (first use in this function)
>>mapscript_wrap.c:69: error: `msg' undeclared (first use in this function)
>>mapscript_wrap.c: At top level:
>>mapscript_wrap.c:107: error: parse error before '*' token
>>mapscript_wrap.c: In function `SWIG_JavaException':
>>mapscript_wrap.c:109: error: `code' undeclared (first use in this function)
>>mapscript_wrap.c:137: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:137: error: `msg' undeclared (first use in this function)
>>mapscript_wrap.c:239: error: parse error before '*' token
>>mapscript_wrap.c: In function `SWIG_JavaArrayInSchar':
>>mapscript_wrap.c:241: error: `jsize' undeclared (first use in this function)
>>mapscript_wrap.c:241: error: parse error before "sz"
>>mapscript_wrap.c:242: error: `input' undeclared (first use in this function)
>>mapscript_wrap.c:243: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:246: error: `sz' undeclared (first use in this function)
>>mapscript_wrap.c:247: error: `jarr' undeclared (first use in this function)
>>mapscript_wrap.c:250: error: `carr' undeclared (first use in this function)
>>mapscript_wrap.c:260: error: parse error before '*' token
>>mapscript_wrap.c: In function `SWIG_JavaArrayArgoutSchar':
>>mapscript_wrap.c:262: error: `jsize' undeclared (first use in this function)
>>mapscript_wrap.c:262: error: parse error before "sz"
>>mapscript_wrap.c:263: error: `sz' undeclared (first use in this function)
>>mapscript_wrap.c:264: error: `jarr' undeclared (first use in this function)
>>mapscript_wrap.c:264: error: `jbyte' undeclared (first use in this function)
>>mapscript_wrap.c:264: error: parse error before "carr"
>>mapscript_wrap.c:265: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:265: error: `input' undeclared (first use in this function)
>>mapscript_wrap.c:268: error: parse error before "SWIG_JavaArrayOutSchar"
>>mapscript_wrap.c:268: error: parse error before '*' token
>>mapscript_wrap.c:268: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `SWIG_JavaArrayOutSchar':
>>mapscript_wrap.c:269: error: `jbyte' undeclared (first use in this function)
>>mapscript_wrap.c:269: error: `arr' undeclared (first use in this function)
>>mapscript_wrap.c:271: error: `jbyteArray' undeclared (first use in this function)
>>mapscript_wrap.c:271: error: parse error before "jresult"
>>mapscript_wrap.c:272: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:273: warning: return makes integer from pointer without a cast
>>mapscript_wrap.c:274: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:276: warning: return makes integer from pointer without a cast
>>mapscript_wrap.c:277: error: `sz' undeclared (first use in this function)
>>mapscript_wrap.c:278: error: parse error before "result"
>>mapscript_wrap.c:285: error: parse error before '*' token
>>mapscript_wrap.c: In function `SWIG_JavaArrayInUchar':
>>mapscript_wrap.c:287: error: `jsize' undeclared (first use in this function)
>>mapscript_wrap.c:287: error: parse error before "sz"
>>mapscript_wrap.c:288: error: `input' undeclared (first use in this function)
>>mapscript_wrap.c:289: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:292: error: `sz' undeclared (first use in this function)
>>mapscript_wrap.c:293: error: `jarr' undeclared (first use in this function)
>>mapscript_wrap.c:296: error: `carr' undeclared (first use in this function)
>>mapscript_wrap.c:306: error: parse error before '*' token
>>mapscript_wrap.c: In function `SWIG_JavaArrayArgoutUchar':
>>mapscript_wrap.c:308: error: `jsize' undeclared (first use in this function)
>>mapscript_wrap.c:308: error: parse error before "sz"
>>mapscript_wrap.c:309: error: `sz' undeclared (first use in this function)
>>mapscript_wrap.c:310: error: `jarr' undeclared (first use in this function)
>>mapscript_wrap.c:310: error: `jshort' undeclared (first use in this function)
>>mapscript_wrap.c:310: error: parse error before "carr"
>>mapscript_wrap.c:311: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:311: error: `input' undeclared (first use in this function)
>>mapscript_wrap.c:314: error: parse error before "SWIG_JavaArrayOutUchar"
>>mapscript_wrap.c:314: error: parse error before '*' token
>>mapscript_wrap.c:314: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `SWIG_JavaArrayOutUchar':
>>mapscript_wrap.c:315: error: `jshort' undeclared (first use in this function)
>>mapscript_wrap.c:315: error: `arr' undeclared (first use in this function)
>>mapscript_wrap.c:317: error: `jshortArray' undeclared (first use in this function)
>>mapscript_wrap.c:317: error: parse error before "jresult"
>>mapscript_wrap.c:318: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:319: warning: return makes integer from pointer without a cast
>>mapscript_wrap.c:320: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:322: warning: return makes integer from pointer without a cast
>>mapscript_wrap.c:323: error: `sz' undeclared (first use in this function)
>>mapscript_wrap.c:324: error: parse error before "result"
>>mapscript_wrap.c:331: error: parse error before '*' token
>>mapscript_wrap.c: In function `SWIG_JavaArrayInShort':
>>mapscript_wrap.c:333: error: `jsize' undeclared (first use in this function)
>>mapscript_wrap.c:333: error: parse error before "sz"
>>mapscript_wrap.c:334: error: `input' undeclared (first use in this function)
>>mapscript_wrap.c:335: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:338: error: `sz' undeclared (first use in this function)
>>mapscript_wrap.c:339: error: `jarr' undeclared (first use in this function)
>>mapscript_wrap.c:342: error: `carr' undeclared (first use in this function)
>>mapscript_wrap.c:352: error: parse error before '*' token
>>mapscript_wrap.c: In function `SWIG_JavaArrayArgoutShort':
>>mapscript_wrap.c:354: error: `jsize' undeclared (first use in this function)
>>mapscript_wrap.c:354: error: parse error before "sz"
>>mapscript_wrap.c:355: error: `sz' undeclared (first use in this function)
>>mapscript_wrap.c:356: error: `jarr' undeclared (first use in this function)
>>mapscript_wrap.c:356: error: `jshort' undeclared (first use in this function)
>>mapscript_wrap.c:356: error: parse error before "carr"
>>mapscript_wrap.c:357: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:357: error: `input' undeclared (first use in this function)
>>mapscript_wrap.c:360: error: parse error before "SWIG_JavaArrayOutShort"
>>mapscript_wrap.c:360: error: parse error before '*' token
>>mapscript_wrap.c:360: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `SWIG_JavaArrayOutShort':
>>mapscript_wrap.c:361: error: `jshort' undeclared (first use in this function)
>>mapscript_wrap.c:361: error: `arr' undeclared (first use in this function)
>>mapscript_wrap.c:363: error: `jshortArray' undeclared (first use in this function)
>>mapscript_wrap.c:363: error: parse error before "jresult"
>>mapscript_wrap.c:364: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:365: warning: return makes integer from pointer without a cast
>>mapscript_wrap.c:366: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:368: warning: return makes integer from pointer without a cast
>>mapscript_wrap.c:369: error: `sz' undeclared (first use in this function)
>>mapscript_wrap.c:370: error: parse error before "result"
>>mapscript_wrap.c:377: error: parse error before '*' token
>>mapscript_wrap.c: In function `SWIG_JavaArrayInUshort':
>>mapscript_wrap.c:379: error: `jsize' undeclared (first use in this function)
>>mapscript_wrap.c:379: error: parse error before "sz"
>>mapscript_wrap.c:380: error: `input' undeclared (first use in this function)
>>mapscript_wrap.c:381: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:384: error: `sz' undeclared (first use in this function)
>>mapscript_wrap.c:385: error: `jarr' undeclared (first use in this function)
>>mapscript_wrap.c:388: error: `carr' undeclared (first use in this function)
>>mapscript_wrap.c:398: error: parse error before '*' token
>>mapscript_wrap.c: In function `SWIG_JavaArrayArgoutUshort':
>>mapscript_wrap.c:400: error: `jsize' undeclared (first use in this function)
>>mapscript_wrap.c:400: error: parse error before "sz"
>>mapscript_wrap.c:401: error: `sz' undeclared (first use in this function)
>>mapscript_wrap.c:402: error: `jarr' undeclared (first use in this function)
>>mapscript_wrap.c:402: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:402: error: parse error before "carr"
>>mapscript_wrap.c:403: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:403: error: `input' undeclared (first use in this function)
>>mapscript_wrap.c:406: error: parse error before "SWIG_JavaArrayOutUshort"
>>mapscript_wrap.c:406: error: parse error before '*' token
>>mapscript_wrap.c:406: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `SWIG_JavaArrayOutUshort':
>>mapscript_wrap.c:407: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:407: error: `arr' undeclared (first use in this function)
>>mapscript_wrap.c:409: error: `jintArray' undeclared (first use in this function)
>>mapscript_wrap.c:409: error: parse error before "jresult"
>>mapscript_wrap.c:410: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:411: warning: return makes integer from pointer without a cast
>>mapscript_wrap.c:412: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:414: warning: return makes integer from pointer without a cast
>>mapscript_wrap.c:415: error: `sz' undeclared (first use in this function)
>>mapscript_wrap.c:416: error: parse error before "result"
>>mapscript_wrap.c:423: error: parse error before '*' token
>>mapscript_wrap.c: In function `SWIG_JavaArrayInInt':
>>mapscript_wrap.c:425: error: `jsize' undeclared (first use in this function)
>>mapscript_wrap.c:425: error: parse error before "sz"
>>mapscript_wrap.c:426: error: `input' undeclared (first use in this function)
>>mapscript_wrap.c:427: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:430: error: `sz' undeclared (first use in this function)
>>mapscript_wrap.c:431: error: `jarr' undeclared (first use in this function)
>>mapscript_wrap.c:434: error: `carr' undeclared (first use in this function)
>>mapscript_wrap.c:444: error: parse error before '*' token
>>mapscript_wrap.c: In function `SWIG_JavaArrayArgoutInt':
>>mapscript_wrap.c:446: error: `jsize' undeclared (first use in this function)
>>mapscript_wrap.c:446: error: parse error before "sz"
>>mapscript_wrap.c:447: error: `sz' undeclared (first use in this function)
>>mapscript_wrap.c:448: error: `jarr' undeclared (first use in this function)
>>mapscript_wrap.c:448: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:448: error: parse error before "carr"
>>mapscript_wrap.c:449: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:449: error: `input' undeclared (first use in this function)
>>mapscript_wrap.c:452: error: parse error before "SWIG_JavaArrayOutInt"
>>mapscript_wrap.c:452: error: parse error before '*' token
>>mapscript_wrap.c:452: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `SWIG_JavaArrayOutInt':
>>mapscript_wrap.c:453: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:453: error: `arr' undeclared (first use in this function)
>>mapscript_wrap.c:455: error: `jintArray' undeclared (first use in this function)
>>mapscript_wrap.c:455: error: parse error before "jresult"
>>mapscript_wrap.c:456: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:457: warning: return makes integer from pointer without a cast
>>mapscript_wrap.c:458: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:460: warning: return makes integer from pointer without a cast
>>mapscript_wrap.c:461: error: `sz' undeclared (first use in this function)
>>mapscript_wrap.c:462: error: parse error before "result"
>>mapscript_wrap.c:469: error: parse error before '*' token
>>mapscript_wrap.c: In function `SWIG_JavaArrayInUint':
>>mapscript_wrap.c:471: error: `jsize' undeclared (first use in this function)
>>mapscript_wrap.c:471: error: parse error before "sz"
>>mapscript_wrap.c:472: error: `input' undeclared (first use in this function)
>>mapscript_wrap.c:473: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:476: error: `sz' undeclared (first use in this function)
>>mapscript_wrap.c:477: error: `jarr' undeclared (first use in this function)
>>mapscript_wrap.c:480: error: `carr' undeclared (first use in this function)
>>mapscript_wrap.c:490: error: parse error before '*' token
>>mapscript_wrap.c: In function `SWIG_JavaArrayArgoutUint':
>>mapscript_wrap.c:492: error: `jsize' undeclared (first use in this function)
>>mapscript_wrap.c:492: error: parse error before "sz"
>>mapscript_wrap.c:493: error: `sz' undeclared (first use in this function)
>>mapscript_wrap.c:494: error: `jarr' undeclared (first use in this function)
>>mapscript_wrap.c:494: error: `jlong' undeclared (first use in this function)
>>mapscript_wrap.c:494: error: parse error before "carr"
>>mapscript_wrap.c:495: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:495: error: `input' undeclared (first use in this function)
>>mapscript_wrap.c:498: error: parse error before "SWIG_JavaArrayOutUint"
>>mapscript_wrap.c:498: error: parse error before '*' token
>>mapscript_wrap.c:498: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `SWIG_JavaArrayOutUint':
>>mapscript_wrap.c:499: error: `jlong' undeclared (first use in this function)
>>mapscript_wrap.c:499: error: `arr' undeclared (first use in this function)
>>mapscript_wrap.c:501: error: `jlongArray' undeclared (first use in this function)
>>mapscript_wrap.c:501: error: parse error before "jresult"
>>mapscript_wrap.c:502: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:503: warning: return makes integer from pointer without a cast
>>mapscript_wrap.c:504: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:506: warning: return makes integer from pointer without a cast
>>mapscript_wrap.c:507: error: `sz' undeclared (first use in this function)
>>mapscript_wrap.c:508: error: parse error before "result"
>>mapscript_wrap.c:515: error: parse error before '*' token
>>mapscript_wrap.c: In function `SWIG_JavaArrayInLong':
>>mapscript_wrap.c:517: error: `jsize' undeclared (first use in this function)
>>mapscript_wrap.c:517: error: parse error before "sz"
>>mapscript_wrap.c:518: error: `input' undeclared (first use in this function)
>>mapscript_wrap.c:519: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:522: error: `sz' undeclared (first use in this function)
>>mapscript_wrap.c:523: error: `jarr' undeclared (first use in this function)
>>mapscript_wrap.c:526: error: `carr' undeclared (first use in this function)
>>mapscript_wrap.c:536: error: parse error before '*' token
>>mapscript_wrap.c: In function `SWIG_JavaArrayArgoutLong':
>>mapscript_wrap.c:538: error: `jsize' undeclared (first use in this function)
>>mapscript_wrap.c:538: error: parse error before "sz"
>>mapscript_wrap.c:539: error: `sz' undeclared (first use in this function)
>>mapscript_wrap.c:540: error: `jarr' undeclared (first use in this function)
>>mapscript_wrap.c:540: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:540: error: parse error before "carr"
>>mapscript_wrap.c:541: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:541: error: `input' undeclared (first use in this function)
>>mapscript_wrap.c:544: error: parse error before "SWIG_JavaArrayOutLong"
>>mapscript_wrap.c:544: error: parse error before '*' token
>>mapscript_wrap.c:544: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `SWIG_JavaArrayOutLong':
>>mapscript_wrap.c:545: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:545: error: `arr' undeclared (first use in this function)
>>mapscript_wrap.c:547: error: `jintArray' undeclared (first use in this function)
>>mapscript_wrap.c:547: error: parse error before "jresult"
>>mapscript_wrap.c:548: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:549: warning: return makes integer from pointer without a cast
>>mapscript_wrap.c:550: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:552: warning: return makes integer from pointer without a cast
>>mapscript_wrap.c:553: error: `sz' undeclared (first use in this function)
>>mapscript_wrap.c:554: error: parse error before "result"
>>mapscript_wrap.c:561: error: parse error before '*' token
>>mapscript_wrap.c: In function `SWIG_JavaArrayInUlong':
>>mapscript_wrap.c:563: error: `jsize' undeclared (first use in this function)
>>mapscript_wrap.c:563: error: parse error before "sz"
>>mapscript_wrap.c:564: error: `input' undeclared (first use in this function)
>>mapscript_wrap.c:565: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:568: error: `sz' undeclared (first use in this function)
>>mapscript_wrap.c:569: error: `jarr' undeclared (first use in this function)
>>mapscript_wrap.c:572: error: `carr' undeclared (first use in this function)
>>mapscript_wrap.c:582: error: parse error before '*' token
>>mapscript_wrap.c: In function `SWIG_JavaArrayArgoutUlong':
>>mapscript_wrap.c:584: error: `jsize' undeclared (first use in this function)
>>mapscript_wrap.c:584: error: parse error before "sz"
>>mapscript_wrap.c:585: error: `sz' undeclared (first use in this function)
>>mapscript_wrap.c:586: error: `jarr' undeclared (first use in this function)
>>mapscript_wrap.c:586: error: `jlong' undeclared (first use in this function)
>>mapscript_wrap.c:586: error: parse error before "carr"
>>mapscript_wrap.c:587: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:587: error: `input' undeclared (first use in this function)
>>mapscript_wrap.c:590: error: parse error before "SWIG_JavaArrayOutUlong"
>>mapscript_wrap.c:590: error: parse error before '*' token
>>mapscript_wrap.c:590: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `SWIG_JavaArrayOutUlong':
>>mapscript_wrap.c:591: error: `jlong' undeclared (first use in this function)
>>mapscript_wrap.c:591: error: `arr' undeclared (first use in this function)
>>mapscript_wrap.c:593: error: `jlongArray' undeclared (first use in this function)
>>mapscript_wrap.c:593: error: parse error before "jresult"
>>mapscript_wrap.c:594: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:595: warning: return makes integer from pointer without a cast
>>mapscript_wrap.c:596: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:598: warning: return makes integer from pointer without a cast
>>mapscript_wrap.c:599: error: `sz' undeclared (first use in this function)
>>mapscript_wrap.c:600: error: parse error before "result"
>>mapscript_wrap.c:607: error: parse error before '*' token
>>mapscript_wrap.c: In function `SWIG_JavaArrayInLonglong':
>>mapscript_wrap.c:609: error: `jsize' undeclared (first use in this function)
>>mapscript_wrap.c:609: error: parse error before "sz"
>>mapscript_wrap.c:610: error: `input' undeclared (first use in this function)
>>mapscript_wrap.c:611: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:614: error: `sz' undeclared (first use in this function)
>>mapscript_wrap.c:615: error: `jarr' undeclared (first use in this function)
>>mapscript_wrap.c:618: error: `carr' undeclared (first use in this function)
>>mapscript_wrap.c:618: error: `jlong' undeclared (first use in this function)
>>mapscript_wrap.c:618: error: parse error before ')' token
>>mapscript_wrap.c:628: error: parse error before '*' token
>>mapscript_wrap.c: In function `SWIG_JavaArrayArgoutLonglong':
>>mapscript_wrap.c:630: error: `jsize' undeclared (first use in this function)
>>mapscript_wrap.c:630: error: parse error before "sz"
>>mapscript_wrap.c:631: error: `sz' undeclared (first use in this function)
>>mapscript_wrap.c:632: error: `jarr' undeclared (first use in this function)
>>mapscript_wrap.c:632: error: `jlong' undeclared (first use in this function)
>>mapscript_wrap.c:632: error: parse error before "carr"
>>mapscript_wrap.c:633: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:633: error: `input' undeclared (first use in this function)
>>mapscript_wrap.c:636: error: parse error before "SWIG_JavaArrayOutLonglong"
>>mapscript_wrap.c:636: error: parse error before '*' token
>>mapscript_wrap.c:636: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `SWIG_JavaArrayOutLonglong':
>>mapscript_wrap.c:637: error: `jlong' undeclared (first use in this function)
>>mapscript_wrap.c:637: error: `arr' undeclared (first use in this function)
>>mapscript_wrap.c:639: error: `jlongArray' undeclared (first use in this function)
>>mapscript_wrap.c:639: error: parse error before "jresult"
>>mapscript_wrap.c:640: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:641: warning: return makes integer from pointer without a cast
>>mapscript_wrap.c:642: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:644: warning: return makes integer from pointer without a cast
>>mapscript_wrap.c:645: error: `sz' undeclared (first use in this function)
>>mapscript_wrap.c:646: error: parse error before "result"
>>mapscript_wrap.c:653: error: parse error before '*' token
>>mapscript_wrap.c: In function `SWIG_JavaArrayInFloat':
>>mapscript_wrap.c:655: error: `jsize' undeclared (first use in this function)
>>mapscript_wrap.c:655: error: parse error before "sz"
>>mapscript_wrap.c:656: error: `input' undeclared (first use in this function)
>>mapscript_wrap.c:657: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:660: error: `sz' undeclared (first use in this function)
>>mapscript_wrap.c:661: error: `jarr' undeclared (first use in this function)
>>mapscript_wrap.c:664: error: `carr' undeclared (first use in this function)
>>mapscript_wrap.c:674: error: parse error before '*' token
>>mapscript_wrap.c: In function `SWIG_JavaArrayArgoutFloat':
>>mapscript_wrap.c:676: error: `jsize' undeclared (first use in this function)
>>mapscript_wrap.c:676: error: parse error before "sz"
>>mapscript_wrap.c:677: error: `sz' undeclared (first use in this function)
>>mapscript_wrap.c:678: error: `jarr' undeclared (first use in this function)
>>mapscript_wrap.c:678: error: `jfloat' undeclared (first use in this function)
>>mapscript_wrap.c:678: error: parse error before "carr"
>>mapscript_wrap.c:679: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:679: error: `input' undeclared (first use in this function)
>>mapscript_wrap.c:682: error: parse error before "SWIG_JavaArrayOutFloat"
>>mapscript_wrap.c:682: error: parse error before '*' token
>>mapscript_wrap.c:682: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `SWIG_JavaArrayOutFloat':
>>mapscript_wrap.c:683: error: `jfloat' undeclared (first use in this function)
>>mapscript_wrap.c:683: error: `arr' undeclared (first use in this function)
>>mapscript_wrap.c:685: error: `jfloatArray' undeclared (first use in this function)
>>mapscript_wrap.c:685: error: parse error before "jresult"
>>mapscript_wrap.c:686: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:687: warning: return makes integer from pointer without a cast
>>mapscript_wrap.c:688: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:690: warning: return makes integer from pointer without a cast
>>mapscript_wrap.c:691: error: `sz' undeclared (first use in this function)
>>mapscript_wrap.c:692: error: parse error before "result"
>>mapscript_wrap.c:699: error: parse error before '*' token
>>mapscript_wrap.c: In function `SWIG_JavaArrayInDouble':
>>mapscript_wrap.c:701: error: `jsize' undeclared (first use in this function)
>>mapscript_wrap.c:701: error: parse error before "sz"
>>mapscript_wrap.c:702: error: `input' undeclared (first use in this function)
>>mapscript_wrap.c:703: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:706: error: `sz' undeclared (first use in this function)
>>mapscript_wrap.c:707: error: `jarr' undeclared (first use in this function)
>>mapscript_wrap.c:710: error: `carr' undeclared (first use in this function)
>>mapscript_wrap.c:720: error: parse error before '*' token
>>mapscript_wrap.c: In function `SWIG_JavaArrayArgoutDouble':
>>mapscript_wrap.c:722: error: `jsize' undeclared (first use in this function)
>>mapscript_wrap.c:722: error: parse error before "sz"
>>mapscript_wrap.c:723: error: `sz' undeclared (first use in this function)
>>mapscript_wrap.c:724: error: `jarr' undeclared (first use in this function)
>>mapscript_wrap.c:724: error: `jdouble' undeclared (first use in this function)
>>mapscript_wrap.c:724: error: parse error before "carr"
>>mapscript_wrap.c:725: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:725: error: `input' undeclared (first use in this function)
>>mapscript_wrap.c:728: error: parse error before "SWIG_JavaArrayOutDouble"
>>mapscript_wrap.c:728: error: parse error before '*' token
>>mapscript_wrap.c:728: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `SWIG_JavaArrayOutDouble':
>>mapscript_wrap.c:729: error: `jdouble' undeclared (first use in this function)
>>mapscript_wrap.c:729: error: `arr' undeclared (first use in this function)
>>mapscript_wrap.c:731: error: `jdoubleArray' undeclared (first use in this function)
>>mapscript_wrap.c:731: error: parse error before "jresult"
>>mapscript_wrap.c:732: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:733: warning: return makes integer from pointer without a cast
>>mapscript_wrap.c:734: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:736: warning: return makes integer from pointer without a cast
>>mapscript_wrap.c:737: error: `sz' undeclared (first use in this function)
>>mapscript_wrap.c:738: error: parse error before "result"
>>mapscript_wrap.c:3116: error: parse error before "jlong"
>>mapscript_wrap.c:3116: error: parse error before '*' token
>>mapscript_wrap.c:3116: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1intarray':
>>mapscript_wrap.c:3117: error: `jlong' undeclared (first use in this function)
>>mapscript_wrap.c:3117: error: parse error before "jresult"
>>mapscript_wrap.c:3121: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:3122: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:3123: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:3126: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:3131: error: syntax error before "void"
>>mapscript_wrap.c:3131: error: parse error before '*' token
>>mapscript_wrap.c:3131: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1intarray':
>>mapscript_wrap.c:3134: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:3135: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:3136: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:3142: error: parse error before "jint"
>>mapscript_wrap.c:3142: error: parse error before '*' token
>>mapscript_wrap.c:3142: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_intarray_1getitem':
>>mapscript_wrap.c:3143: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:3143: error: parse error before "jresult"
>>mapscript_wrap.c:3148: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:3149: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:3150: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:3151: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:3154: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:3154: error: parse error before "result"
>>mapscript_wrap.c:3159: error: syntax error before "void"
>>mapscript_wrap.c:3159: error: parse error before '*' token
>>mapscript_wrap.c:3159: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_intarray_1setitem':
>>mapscript_wrap.c:3164: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:3165: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:3166: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:3167: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:3168: error: `jarg3' undeclared (first use in this function)
>>mapscript_wrap.c:3174: error: parse error before "jlong"
>>mapscript_wrap.c:3174: error: parse error before '*' token
>>mapscript_wrap.c:3174: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_intarray_1cast':
>>mapscript_wrap.c:3175: error: `jlong' undeclared (first use in this function)
>>mapscript_wrap.c:3175: error: parse error before "jresult"
>>mapscript_wrap.c:3179: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:3180: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:3181: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:3184: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:3189: error: parse error before "jlong"
>>mapscript_wrap.c:3189: error: parse error before '*' token
>>mapscript_wrap.c:3189: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_intarray_1frompointer':
>>mapscript_wrap.c:3190: error: `jlong' undeclared (first use in this function)
>>mapscript_wrap.c:3190: error: parse error before "jresult"
>>mapscript_wrap.c:3194: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:3195: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:3196: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:3199: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:3204: error: parse error before "jstring"
>>mapscript_wrap.c:3204: error: parse error before '*' token
>>mapscript_wrap.c:3204: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1VERSION':
>>mapscript_wrap.c:3205: error: `jstring' undeclared (first use in this function)
>>mapscript_wrap.c:3205: error: parse error before "jresult"
>>mapscript_wrap.c:3208: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:3209: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:3246: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:3252: error: parse error before "jint"
>>mapscript_wrap.c:3252: error: parse error before '*' token
>>mapscript_wrap.c:3252: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1TRUE':
>>mapscript_wrap.c:3253: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:3253: error: parse error before "jresult"
>>mapscript_wrap.c:3256: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:3257: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:3293: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:3293: error: parse error before "result"
>>mapscript_wrap.c:3298: error: parse error before "jint"
>>mapscript_wrap.c:3298: error: parse error before '*' token
>>mapscript_wrap.c:3298: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1FALSE':
>>mapscript_wrap.c:3299: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:3299: error: parse error before "jresult"
>>mapscript_wrap.c:3302: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:3303: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:3339: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:3339: error: parse error before "result"
>>mapscript_wrap.c:3344: error: parse error before "jint"
>>mapscript_wrap.c:3344: error: parse error before '*' token
>>mapscript_wrap.c:3344: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1ON':
>>mapscript_wrap.c:3345: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:3345: error: parse error before "jresult"
>>mapscript_wrap.c:3348: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:3349: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:3385: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:3385: error: parse error before "result"
>>mapscript_wrap.c:3390: error: parse error before "jint"
>>mapscript_wrap.c:3390: error: parse error before '*' token
>>mapscript_wrap.c:3390: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1OFF':
>>mapscript_wrap.c:3391: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:3391: error: parse error before "jresult"
>>mapscript_wrap.c:3394: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:3395: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:3431: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:3431: error: parse error before "result"
>>mapscript_wrap.c:3436: error: parse error before "jint"
>>mapscript_wrap.c:3436: error: parse error before '*' token
>>mapscript_wrap.c:3436: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1DEFAULT':
>>mapscript_wrap.c:3437: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:3437: error: parse error before "jresult"
>>mapscript_wrap.c:3440: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:3441: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:3477: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:3477: error: parse error before "result"
>>mapscript_wrap.c:3482: error: parse error before "jint"
>>mapscript_wrap.c:3482: error: parse error before '*' token
>>mapscript_wrap.c:3482: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1EMBED':
>>mapscript_wrap.c:3483: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:3483: error: parse error before "jresult"
>>mapscript_wrap.c:3486: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:3487: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:3523: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:3523: error: parse error before "result"
>>mapscript_wrap.c:3528: error: parse error before "jint"
>>mapscript_wrap.c:3528: error: parse error before '*' token
>>mapscript_wrap.c:3528: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1DELETE':
>>mapscript_wrap.c:3529: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:3529: error: parse error before "jresult"
>>mapscript_wrap.c:3532: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:3533: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:3569: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:3569: error: parse error before "result"
>>mapscript_wrap.c:3574: error: parse error before "jint"
>>mapscript_wrap.c:3574: error: parse error before '*' token
>>mapscript_wrap.c:3574: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1YES':
>>mapscript_wrap.c:3575: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:3575: error: parse error before "jresult"
>>mapscript_wrap.c:3578: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:3579: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:3615: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:3615: error: parse error before "result"
>>mapscript_wrap.c:3620: error: parse error before "jint"
>>mapscript_wrap.c:3620: error: parse error before '*' token
>>mapscript_wrap.c:3620: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1NO':
>>mapscript_wrap.c:3621: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:3621: error: parse error before "jresult"
>>mapscript_wrap.c:3624: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:3625: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:3661: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:3661: error: parse error before "result"
>>mapscript_wrap.c:3666: error: parse error before "jint"
>>mapscript_wrap.c:3666: error: parse error before '*' token
>>mapscript_wrap.c:3666: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1SINGLE':
>>mapscript_wrap.c:3667: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:3667: error: parse error before "jresult"
>>mapscript_wrap.c:3670: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:3671: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:3707: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:3707: error: parse error before "result"
>>mapscript_wrap.c:3712: error: parse error before "jint"
>>mapscript_wrap.c:3712: error: parse error before '*' token
>>mapscript_wrap.c:3712: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1MULTIPLE':
>>mapscript_wrap.c:3713: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:3713: error: parse error before "jresult"
>>mapscript_wrap.c:3716: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:3717: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:3753: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:3753: error: parse error before "result"
>>mapscript_wrap.c:3758: error: parse error before "jint"
>>mapscript_wrap.c:3758: error: parse error before '*' token
>>mapscript_wrap.c:3758: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1GD_1ALPHA':
>>mapscript_wrap.c:3759: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:3759: error: parse error before "jresult"
>>mapscript_wrap.c:3762: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:3763: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:3799: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:3799: error: parse error before "result"
>>mapscript_wrap.c:3804: error: parse error before "jstring"
>>mapscript_wrap.c:3804: error: parse error before '*' token
>>mapscript_wrap.c:3804: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1fontSetObj_1filename':
>>mapscript_wrap.c:3805: error: `jstring' undeclared (first use in this function)
>>mapscript_wrap.c:3805: error: parse error before "jresult"
>>mapscript_wrap.c:3809: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:3810: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:3811: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:3815: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:3821: error: parse error before "jint"
>>mapscript_wrap.c:3821: error: parse error before '*' token
>>mapscript_wrap.c:3821: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1fontSetObj_1numfonts':
>>mapscript_wrap.c:3822: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:3822: error: parse error before "jresult"
>>mapscript_wrap.c:3826: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:3827: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:3828: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:3831: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:3831: error: parse error before "result"
>>mapscript_wrap.c:3836: error: syntax error before "void"
>>mapscript_wrap.c:3836: error: parse error before '*' token
>>mapscript_wrap.c:3836: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1fontSetObj_1fonts':
>>mapscript_wrap.c:3840: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:3841: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:3842: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:3843: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:3849: error: parse error before "jlong"
>>mapscript_wrap.c:3849: error: parse error before '*' token
>>mapscript_wrap.c:3849: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1fontSetObj_1fonts':
>>mapscript_wrap.c:3850: error: `jlong' undeclared (first use in this function)
>>mapscript_wrap.c:3850: error: parse error before "jresult"
>>mapscript_wrap.c:3854: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:3855: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:3856: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:3859: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:3864: error: parse error before "jlong"
>>mapscript_wrap.c:3864: error: parse error before '*' token
>>mapscript_wrap.c:3864: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1fontSetObj':
>>mapscript_wrap.c:3865: error: `jlong' undeclared (first use in this function)
>>mapscript_wrap.c:3865: error: parse error before "jresult"
>>mapscript_wrap.c:3868: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:3869: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:3905: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:3910: error: syntax error before "void"
>>mapscript_wrap.c:3910: error: parse error before '*' token
>>mapscript_wrap.c:3910: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1fontSetObj':
>>mapscript_wrap.c:3913: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:3914: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:3915: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:3954: error: syntax error before "void"
>>mapscript_wrap.c:3954: error: parse error before '*' token
>>mapscript_wrap.c:3954: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1outputFormatObj_1name':
>>mapscript_wrap.c:3958: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:3959: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:3960: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:3963: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:3965: warning: `return' with no value, in function returning non-void
>>mapscript_wrap.c:3983: error: parse error before "jstring"
>>mapscript_wrap.c:3983: error: parse error before '*' token
>>mapscript_wrap.c:3983: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1outputFormatObj_1name':
>>mapscript_wrap.c:3984: error: `jstring' undeclared (first use in this function)
>>mapscript_wrap.c:3984: error: parse error before "jresult"
>>mapscript_wrap.c:3988: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:3989: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:3990: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:3994: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:4000: error: syntax error before "void"
>>mapscript_wrap.c:4000: error: parse error before '*' token
>>mapscript_wrap.c:4000: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1outputFormatObj_1mimetype':
>>mapscript_wrap.c:4004: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4005: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4006: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4009: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:4011: warning: `return' with no value, in function returning non-void
>>mapscript_wrap.c:4029: error: parse error before "jstring"
>>mapscript_wrap.c:4029: error: parse error before '*' token
>>mapscript_wrap.c:4029: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1outputFormatObj_1mimetype':
>>mapscript_wrap.c:4030: error: `jstring' undeclared (first use in this function)
>>mapscript_wrap.c:4030: error: parse error before "jresult"
>>mapscript_wrap.c:4034: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4035: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4036: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4040: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:4046: error: syntax error before "void"
>>mapscript_wrap.c:4046: error: parse error before '*' token
>>mapscript_wrap.c:4046: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1outputFormatObj_1driver':
>>mapscript_wrap.c:4050: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4051: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4052: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4055: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:4057: warning: `return' with no value, in function returning non-void
>>mapscript_wrap.c:4075: error: parse error before "jstring"
>>mapscript_wrap.c:4075: error: parse error before '*' token
>>mapscript_wrap.c:4075: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1outputFormatObj_1driver':
>>mapscript_wrap.c:4076: error: `jstring' undeclared (first use in this function)
>>mapscript_wrap.c:4076: error: parse error before "jresult"
>>mapscript_wrap.c:4080: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4081: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4082: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4086: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:4092: error: syntax error before "void"
>>mapscript_wrap.c:4092: error: parse error before '*' token
>>mapscript_wrap.c:4092: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1outputFormatObj_1extension':
>>mapscript_wrap.c:4096: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4097: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4098: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4101: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:4103: warning: `return' with no value, in function returning non-void
>>mapscript_wrap.c:4121: error: parse error before "jstring"
>>mapscript_wrap.c:4121: error: parse error before '*' token
>>mapscript_wrap.c:4121: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1outputFormatObj_1extension':
>>mapscript_wrap.c:4122: error: `jstring' undeclared (first use in this function)
>>mapscript_wrap.c:4122: error: parse error before "jresult"
>>mapscript_wrap.c:4126: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4127: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4128: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4132: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:4138: error: syntax error before "void"
>>mapscript_wrap.c:4138: error: parse error before '*' token
>>mapscript_wrap.c:4138: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1outputFormatObj_1renderer':
>>mapscript_wrap.c:4142: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4143: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4144: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4145: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:4151: error: parse error before "jint"
>>mapscript_wrap.c:4151: error: parse error before '*' token
>>mapscript_wrap.c:4151: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1outputFormatObj_1renderer':
>>mapscript_wrap.c:4152: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:4152: error: parse error before "jresult"
>>mapscript_wrap.c:4156: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4157: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4158: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4161: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:4161: error: parse error before "result"
>>mapscript_wrap.c:4166: error: syntax error before "void"
>>mapscript_wrap.c:4166: error: parse error before '*' token
>>mapscript_wrap.c:4166: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1outputFormatObj_1imagemode':
>>mapscript_wrap.c:4170: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4171: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4172: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4173: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:4179: error: parse error before "jint"
>>mapscript_wrap.c:4179: error: parse error before '*' token
>>mapscript_wrap.c:4179: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1outputFormatObj_1imagemode':
>>mapscript_wrap.c:4180: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:4180: error: parse error before "jresult"
>>mapscript_wrap.c:4184: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4185: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4186: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4189: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:4189: error: parse error before "result"
>>mapscript_wrap.c:4194: error: syntax error before "void"
>>mapscript_wrap.c:4194: error: parse error before '*' token
>>mapscript_wrap.c:4194: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1outputFormatObj_1transparent':
>>mapscript_wrap.c:4198: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4199: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4200: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4201: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:4207: error: parse error before "jint"
>>mapscript_wrap.c:4207: error: parse error before '*' token
>>mapscript_wrap.c:4207: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1outputFormatObj_1transparent':
>>mapscript_wrap.c:4208: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:4208: error: parse error before "jresult"
>>mapscript_wrap.c:4212: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4213: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4214: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4217: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:4217: error: parse error before "result"
>>mapscript_wrap.c:4222: error: syntax error before "void"
>>mapscript_wrap.c:4222: error: parse error before '*' token
>>mapscript_wrap.c:4222: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1outputFormatObj_1bands':
>>mapscript_wrap.c:4226: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4227: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4228: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4229: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:4235: error: parse error before "jint"
>>mapscript_wrap.c:4235: error: parse error before '*' token
>>mapscript_wrap.c:4235: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1outputFormatObj_1bands':
>>mapscript_wrap.c:4236: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:4236: error: parse error before "jresult"
>>mapscript_wrap.c:4240: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4241: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4242: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4245: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:4245: error: parse error before "result"
>>mapscript_wrap.c:4250: error: syntax error before "void"
>>mapscript_wrap.c:4250: error: parse error before '*' token
>>mapscript_wrap.c:4250: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1outputFormatObj_1numformatoptions':
>>mapscript_wrap.c:4254: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4255: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4256: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4257: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:4263: error: parse error before "jint"
>>mapscript_wrap.c:4263: error: parse error before '*' token
>>mapscript_wrap.c:4263: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1outputFormatObj_1numformatoptions':
>>mapscript_wrap.c:4264: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:4264: error: parse error before "jresult"
>>mapscript_wrap.c:4268: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4269: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4270: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4273: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:4273: error: parse error before "result"
>>mapscript_wrap.c:4278: error: syntax error before "void"
>>mapscript_wrap.c:4278: error: parse error before '*' token
>>mapscript_wrap.c:4278: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1outputFormatObj_1formatoptions':
>>mapscript_wrap.c:4282: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4283: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4284: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4285: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:4291: error: parse error before "jlong"
>>mapscript_wrap.c:4291: error: parse error before '*' token
>>mapscript_wrap.c:4291: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1outputFormatObj_1formatoptions':
>>mapscript_wrap.c:4292: error: `jlong' undeclared (first use in this function)
>>mapscript_wrap.c:4292: error: parse error before "jresult"
>>mapscript_wrap.c:4296: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4297: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4298: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4301: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:4306: error: syntax error before "void"
>>mapscript_wrap.c:4306: error: parse error before '*' token
>>mapscript_wrap.c:4306: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1outputFormatObj_1refcount':
>>mapscript_wrap.c:4310: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4311: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4312: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4313: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:4319: error: parse error before "jint"
>>mapscript_wrap.c:4319: error: parse error before '*' token
>>mapscript_wrap.c:4319: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1outputFormatObj_1refcount':
>>mapscript_wrap.c:4320: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:4320: error: parse error before "jresult"
>>mapscript_wrap.c:4324: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4325: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4326: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4329: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:4329: error: parse error before "result"
>>mapscript_wrap.c:4334: error: syntax error before "void"
>>mapscript_wrap.c:4334: error: parse error before '*' token
>>mapscript_wrap.c:4334: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1outputFormatObj_1inmapfile':
>>mapscript_wrap.c:4338: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4339: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4340: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4341: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:4347: error: parse error before "jint"
>>mapscript_wrap.c:4347: error: parse error before '*' token
>>mapscript_wrap.c:4347: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1outputFormatObj_1inmapfile':
>>mapscript_wrap.c:4348: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:4348: error: parse error before "jresult"
>>mapscript_wrap.c:4352: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4353: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4354: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4357: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:4357: error: parse error before "result"
>>mapscript_wrap.c:4362: error: parse error before "jlong"
>>mapscript_wrap.c:4362: error: parse error before '*' token
>>mapscript_wrap.c:4362: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1outputFormatObj':
>>mapscript_wrap.c:4363: error: `jlong' undeclared (first use in this function)
>>mapscript_wrap.c:4363: error: parse error before "jresult"
>>mapscript_wrap.c:4368: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4369: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4372: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4379: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:4419: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c: At top level:
>>mapscript_wrap.c:4430: error: syntax error before "void"
>>mapscript_wrap.c:4430: error: parse error before '*' token
>>mapscript_wrap.c:4430: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1outputFormatObj':
>>mapscript_wrap.c:4433: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4434: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4435: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4474: error: syntax error before "void"
>>mapscript_wrap.c:4474: error: parse error before '*' token
>>mapscript_wrap.c:4474: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_outputFormatObj_1setOption':
>>mapscript_wrap.c:4479: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4480: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4481: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4484: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:4486: warning: `return' with no value, in function returning non-void
>>mapscript_wrap.c:4491: error: `jarg3' undeclared (first use in this function)
>>mapscript_wrap.c:4493: warning: `return' with no value, in function returning non-void
>>mapscript_wrap.c:4540: error: parse error before "jint"
>>mapscript_wrap.c:4540: error: parse error before '*' token
>>mapscript_wrap.c:4540: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_outputFormatObj_1validate':
>>mapscript_wrap.c:4541: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:4541: error: parse error before "jresult"
>>mapscript_wrap.c:4545: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4546: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4547: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4583: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:4583: error: parse error before "result"
>>mapscript_wrap.c:4588: error: parse error before "jstring"
>>mapscript_wrap.c:4588: error: parse error before '*' token
>>mapscript_wrap.c:4588: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_outputFormatObj_1getOption':
>>mapscript_wrap.c:4589: error: `jstring' undeclared (first use in this function)
>>mapscript_wrap.c:4589: error: parse error before "jresult"
>>mapscript_wrap.c:4595: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4596: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4597: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4600: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:4607: error: `jarg3' undeclared (first use in this function)
>>mapscript_wrap.c:4648: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:4661: error: parse error before "jint"
>>mapscript_wrap.c:4661: error: parse error before '*' token
>>mapscript_wrap.c:4661: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1MS_1NOOVERRIDE':
>>mapscript_wrap.c:4662: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:4662: error: parse error before "jresult"
>>mapscript_wrap.c:4665: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4666: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4702: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:4702: error: parse error before "result"
>>mapscript_wrap.c:4707: error: syntax error before "void"
>>mapscript_wrap.c:4707: error: parse error before '*' token
>>mapscript_wrap.c:4707: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1queryMapObj_1height':
>>mapscript_wrap.c:4711: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4712: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4713: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4714: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:4720: error: parse error before "jint"
>>mapscript_wrap.c:4720: error: parse error before '*' token
>>mapscript_wrap.c:4720: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1queryMapObj_1height':
>>mapscript_wrap.c:4721: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:4721: error: parse error before "jresult"
>>mapscript_wrap.c:4725: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4726: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4727: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4730: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:4730: error: parse error before "result"
>>mapscript_wrap.c:4735: error: syntax error before "void"
>>mapscript_wrap.c:4735: error: parse error before '*' token
>>mapscript_wrap.c:4735: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1queryMapObj_1width':
>>mapscript_wrap.c:4739: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4740: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4741: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4742: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:4748: error: parse error before "jint"
>>mapscript_wrap.c:4748: error: parse error before '*' token
>>mapscript_wrap.c:4748: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1queryMapObj_1width':
>>mapscript_wrap.c:4749: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:4749: error: parse error before "jresult"
>>mapscript_wrap.c:4753: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4754: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4755: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4758: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:4758: error: parse error before "result"
>>mapscript_wrap.c:4763: error: syntax error before "void"
>>mapscript_wrap.c:4763: error: parse error before '*' token
>>mapscript_wrap.c:4763: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1queryMapObj_1status':
>>mapscript_wrap.c:4767: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4768: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4769: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4770: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:4776: error: parse error before "jint"
>>mapscript_wrap.c:4776: error: parse error before '*' token
>>mapscript_wrap.c:4776: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1queryMapObj_1status':
>>mapscript_wrap.c:4777: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:4777: error: parse error before "jresult"
>>mapscript_wrap.c:4781: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4782: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4783: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4786: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:4786: error: parse error before "result"
>>mapscript_wrap.c:4791: error: syntax error before "void"
>>mapscript_wrap.c:4791: error: parse error before '*' token
>>mapscript_wrap.c:4791: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1queryMapObj_1style':
>>mapscript_wrap.c:4795: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4796: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4797: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4798: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:4804: error: parse error before "jint"
>>mapscript_wrap.c:4804: error: parse error before '*' token
>>mapscript_wrap.c:4804: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1queryMapObj_1style':
>>mapscript_wrap.c:4805: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:4805: error: parse error before "jresult"
>>mapscript_wrap.c:4809: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4810: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4811: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4814: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:4814: error: parse error before "result"
>>mapscript_wrap.c:4819: error: syntax error before "void"
>>mapscript_wrap.c:4819: error: parse error before '*' token
>>mapscript_wrap.c:4819: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1queryMapObj_1color':
>>mapscript_wrap.c:4823: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4824: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4825: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4826: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:4832: error: parse error before "jlong"
>>mapscript_wrap.c:4832: error: parse error before '*' token
>>mapscript_wrap.c:4832: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1queryMapObj_1color':
>>mapscript_wrap.c:4833: error: `jlong' undeclared (first use in this function)
>>mapscript_wrap.c:4833: error: parse error before "jresult"
>>mapscript_wrap.c:4837: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4838: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4839: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4842: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:4847: error: parse error before "jlong"
>>mapscript_wrap.c:4847: error: parse error before '*' token
>>mapscript_wrap.c:4847: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_new_1queryMapObj':
>>mapscript_wrap.c:4848: error: `jlong' undeclared (first use in this function)
>>mapscript_wrap.c:4848: error: parse error before "jresult"
>>mapscript_wrap.c:4851: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4852: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4888: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:4893: error: syntax error before "void"
>>mapscript_wrap.c:4893: error: parse error before '*' token
>>mapscript_wrap.c:4893: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1queryMapObj':
>>mapscript_wrap.c:4896: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4897: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4898: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4937: error: syntax error before "void"
>>mapscript_wrap.c:4937: error: parse error before '*' token
>>mapscript_wrap.c:4937: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1font':
>>mapscript_wrap.c:4941: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4942: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4943: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4946: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:4948: warning: `return' with no value, in function returning non-void
>>mapscript_wrap.c:4966: error: parse error before "jstring"
>>mapscript_wrap.c:4966: error: parse error before '*' token
>>mapscript_wrap.c:4966: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1font':
>>mapscript_wrap.c:4967: error: `jstring' undeclared (first use in this function)
>>mapscript_wrap.c:4967: error: parse error before "jresult"
>>mapscript_wrap.c:4971: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4972: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4973: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4977: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:4983: error: syntax error before "void"
>>mapscript_wrap.c:4983: error: parse error before '*' token
>>mapscript_wrap.c:4983: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1type':
>>mapscript_wrap.c:4987: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:4988: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:4989: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:4990: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:4996: error: parse error before "jint"
>>mapscript_wrap.c:4996: error: parse error before '*' token
>>mapscript_wrap.c:4996: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1type':
>>mapscript_wrap.c:4997: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:4997: error: parse error before "jresult"
>>mapscript_wrap.c:5001: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:5002: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:5003: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:5006: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:5006: error: parse error before "result"
>>mapscript_wrap.c:5011: error: syntax error before "void"
>>mapscript_wrap.c:5011: error: parse error before '*' token
>>mapscript_wrap.c:5011: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1color':
>>mapscript_wrap.c:5015: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:5016: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:5017: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:5018: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:5024: error: parse error before "jlong"
>>mapscript_wrap.c:5024: error: parse error before '*' token
>>mapscript_wrap.c:5024: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1color':
>>mapscript_wrap.c:5025: error: `jlong' undeclared (first use in this function)
>>mapscript_wrap.c:5025: error: parse error before "jresult"
>>mapscript_wrap.c:5029: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:5030: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:5031: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:5034: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:5039: error: syntax error before "void"
>>mapscript_wrap.c:5039: error: parse error before '*' token
>>mapscript_wrap.c:5039: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1outlinecolor':
>>mapscript_wrap.c:5043: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:5044: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:5045: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:5046: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:5052: error: parse error before "jlong"
>>mapscript_wrap.c:5052: error: parse error before '*' token
>>mapscript_wrap.c:5052: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1outlinecolor':
>>mapscript_wrap.c:5053: error: `jlong' undeclared (first use in this function)
>>mapscript_wrap.c:5053: error: parse error before "jresult"
>>mapscript_wrap.c:5057: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:5058: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:5059: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:5062: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:5067: error: syntax error before "void"
>>mapscript_wrap.c:5067: error: parse error before '*' token
>>mapscript_wrap.c:5067: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1shadowcolor':
>>mapscript_wrap.c:5071: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:5072: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:5073: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:5074: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:5080: error: parse error before "jlong"
>>mapscript_wrap.c:5080: error: parse error before '*' token
>>mapscript_wrap.c:5080: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1shadowcolor':
>>mapscript_wrap.c:5081: error: `jlong' undeclared (first use in this function)
>>mapscript_wrap.c:5081: error: parse error before "jresult"
>>mapscript_wrap.c:5085: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:5086: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:5087: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:5090: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:5095: error: syntax error before "void"
>>mapscript_wrap.c:5095: error: parse error before '*' token
>>mapscript_wrap.c:5095: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1shadowsizex':
>>mapscript_wrap.c:5099: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:5100: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:5101: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:5102: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:5108: error: parse error before "jint"
>>mapscript_wrap.c:5108: error: parse error before '*' token
>>mapscript_wrap.c:5108: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1shadowsizex':
>>mapscript_wrap.c:5109: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:5109: error: parse error before "jresult"
>>mapscript_wrap.c:5113: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:5114: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:5115: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:5118: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:5118: error: parse error before "result"
>>mapscript_wrap.c:5123: error: syntax error before "void"
>>mapscript_wrap.c:5123: error: parse error before '*' token
>>mapscript_wrap.c:5123: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1shadowsizey':
>>mapscript_wrap.c:5127: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:5128: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:5129: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:5130: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:5136: error: parse error before "jint"
>>mapscript_wrap.c:5136: error: parse error before '*' token
>>mapscript_wrap.c:5136: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1shadowsizey':
>>mapscript_wrap.c:5137: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:5137: error: parse error before "jresult"
>>mapscript_wrap.c:5141: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:5142: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:5143: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:5146: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:5146: error: parse error before "result"
>>mapscript_wrap.c:5151: error: syntax error before "void"
>>mapscript_wrap.c:5151: error: parse error before '*' token
>>mapscript_wrap.c:5151: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1backgroundcolor':
>>mapscript_wrap.c:5155: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:5156: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:5157: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:5158: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:5164: error: parse error before "jlong"
>>mapscript_wrap.c:5164: error: parse error before '*' token
>>mapscript_wrap.c:5164: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1backgroundcolor':
>>mapscript_wrap.c:5165: error: `jlong' undeclared (first use in this function)
>>mapscript_wrap.c:5165: error: parse error before "jresult"
>>mapscript_wrap.c:5169: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:5170: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:5171: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:5174: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:5179: error: syntax error before "void"
>>mapscript_wrap.c:5179: error: parse error before '*' token
>>mapscript_wrap.c:5179: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1backgroundshadowcolor':
>>mapscript_wrap.c:5183: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:5184: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:5185: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:5186: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:5192: error: parse error before "jlong"
>>mapscript_wrap.c:5192: error: parse error before '*' token
>>mapscript_wrap.c:5192: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1backgroundshadowcolor':
>>mapscript_wrap.c:5193: error: `jlong' undeclared (first use in this function)
>>mapscript_wrap.c:5193: error: parse error before "jresult"
>>mapscript_wrap.c:5197: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:5198: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:5199: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:5202: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:5207: error: syntax error before "void"
>>mapscript_wrap.c:5207: error: parse error before '*' token
>>mapscript_wrap.c:5207: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1backgroundshadowsizex':
>>mapscript_wrap.c:5211: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:5212: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:5213: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:5214: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:5220: error: parse error before "jint"
>>mapscript_wrap.c:5220: error: parse error before '*' token
>>mapscript_wrap.c:5220: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1backgroundshadowsizex':
>>mapscript_wrap.c:5221: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:5221: error: parse error before "jresult"
>>mapscript_wrap.c:5225: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:5226: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:5227: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:5230: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:5230: error: parse error before "result"
>>mapscript_wrap.c:5235: error: syntax error before "void"
>>mapscript_wrap.c:5235: error: parse error before '*' token
>>mapscript_wrap.c:5235: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1backgroundshadowsizey':
>>mapscript_wrap.c:5239: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:5240: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:5241: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:5242: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:5248: error: parse error before "jint"
>>mapscript_wrap.c:5248: error: parse error before '*' token
>>mapscript_wrap.c:5248: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1backgroundshadowsizey':
>>mapscript_wrap.c:5249: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:5249: error: parse error before "jresult"
>>mapscript_wrap.c:5253: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:5254: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:5255: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:5258: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:5258: error: parse error before "result"
>>mapscript_wrap.c:5263: error: syntax error before "void"
>>mapscript_wrap.c:5263: error: parse error before '*' token
>>mapscript_wrap.c:5263: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1size':
>>mapscript_wrap.c:5267: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:5268: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:5269: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:5270: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:5276: error: parse error before "jint"
>>mapscript_wrap.c:5276: error: parse error before '*' token
>>mapscript_wrap.c:5276: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1size':
>>mapscript_wrap.c:5277: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:5277: error: parse error before "jresult"
>>mapscript_wrap.c:5281: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:5282: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:5283: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:5286: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:5286: error: parse error before "result"
>>mapscript_wrap.c:5291: error: syntax error before "void"
>>mapscript_wrap.c:5291: error: parse error before '*' token
>>mapscript_wrap.c:5291: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1minsize':
>>mapscript_wrap.c:5295: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:5296: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:5297: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:5298: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:5304: error: parse error before "jint"
>>mapscript_wrap.c:5304: error: parse error before '*' token
>>mapscript_wrap.c:5304: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1minsize':
>>mapscript_wrap.c:5305: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:5305: error: parse error before "jresult"
>>mapscript_wrap.c:5309: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:5310: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:5311: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:5314: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:5314: error: parse error before "result"
>>mapscript_wrap.c:5319: error: syntax error before "void"
>>mapscript_wrap.c:5319: error: parse error before '*' token
>>mapscript_wrap.c:5319: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1maxsize':
>>mapscript_wrap.c:5323: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:5324: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:5325: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:5326: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:5332: error: parse error before "jint"
>>mapscript_wrap.c:5332: error: parse error before '*' token
>>mapscript_wrap.c:5332: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1maxsize':
>>mapscript_wrap.c:5333: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:5333: error: parse error before "jresult"
>>mapscript_wrap.c:5337: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:5338: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:5339: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:5342: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:5342: error: parse error before "result"
>>mapscript_wrap.c:5347: error: syntax error before "void"
>>mapscript_wrap.c:5347: error: parse error before '*' token
>>mapscript_wrap.c:5347: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1position':
>>mapscript_wrap.c:5351: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:5352: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:5353: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:5354: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:5360: error: parse error before "jint"
>>mapscript_wrap.c:5360: error: parse error before '*' token
>>mapscript_wrap.c:5360: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1position':
>>mapscript_wrap.c:5361: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:5361: error: parse error before "jresult"
>>mapscript_wrap.c:5365: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:5366: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:5367: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:5370: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:5370: error: parse error before "result"
>>mapscript_wrap.c:5375: error: syntax error before "void"
>>mapscript_wrap.c:5375: error: parse error before '*' token
>>mapscript_wrap.c:5375: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1offsetx':
>>mapscript_wrap.c:5379: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:5380: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:5381: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:5382: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:5388: error: parse error before "jint"
>>mapscript_wrap.c:5388: error: parse error before '*' token
>>mapscript_wrap.c:5388: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1offsetx':
>>mapscript_wrap.c:5389: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:5389: error: parse error before "jresult"
>>mapscript_wrap.c:5393: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:5394: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:5395: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:5398: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:5398: error: parse error before "result"
>>mapscript_wrap.c:5403: error: syntax error before "void"
>>mapscript_wrap.c:5403: error: parse error before '*' token
>>mapscript_wrap.c:5403: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1offsety':
>>mapscript_wrap.c:5407: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:5408: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:5409: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:5410: error: `jarg2' undeclared (first use in this function)
>>mapscript_wrap.c:5416: error: parse error before "jint"
>>mapscript_wrap.c:5416: error: parse error before '*' token
>>mapscript_wrap.c:5416: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_get_1labelObj_1offsety':
>>mapscript_wrap.c:5417: error: `jint' undeclared (first use in this function)
>>mapscript_wrap.c:5417: error: parse error before "jresult"
>>mapscript_wrap.c:5421: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:5422: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:5423: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:5426: error: `jresult' undeclared (first use in this function)
>>mapscript_wrap.c:5426: error: parse error before "result"
>>mapscript_wrap.c:5431: error: syntax error before "void"
>>mapscript_wrap.c:5431: error: parse error before '*' token
>>mapscript_wrap.c:5431: warning: return type defaults to `int'
>>mapscript_wrap.c: In function `Java_edu_umn_gis_mapscript_mapscriptJNI_set_1labelObj_1angle':
>>mapscript_wrap.c:5435: error: `jenv' undeclared (first use in this function)
>>mapscript_wrap.c:5436: error: `jcls' undeclared (first use in this function)
>>mapscript_wrap.c:5437: error: `jarg1' undeclared (first use in this function)
>>mapscript_wrap.c:5438: error: `jarg2' undeclared (first use in
hello
JAVA_HOME ????
if you mean this:
orkun at landslide:~/work/mapserver-4.6.0/mapscript/java$ printenv | grep java
PWD=/home/orkun/work/mapserver-4.6.0/mapscript/java
But I did not have any environment variable like JAVA_HOME
I tried to produce it:
/mapscript/java$ JAVA_HOME="/usr/local/jdk1.5.0_03/"
then make
it gives same errors.
I am new in java and its installation. I am not sure
if my java installation is correct.
I followed debian installation way.
Later I have java_libs known by
my system.
landslide:/home/orkun# cat /etc/ld.so.conf
/usr/X11R6/lib
/usr/lib/grass/lib
/usr/local/jdk1.5.0_03/lib
mapserver can not still be installed.
I realized later that I had skipped to sent you history's last values.
506 ./ins2 #executable file containing config values
507 make clean
508 make
509 make install
510 cd mapscript
511 cd java
512 make interface
513 make *** errors
514 history 10
regards
______________________________________
XamimeLT - installed on mailserver for domain @deprem.gov.tr
Queries to: postmaster at deprem.gov.tr
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
