java mapscript error
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Wed Jun 22 03:51:30 EDT 2005
> hello
> JAVA_HOME ????
You really should RTFM
> if you mean this:
> orkun at landslide:~/work/mapserver-4.6.0/mapscript/java$ printenv | grep
> java
> PWD=/home/orkun/work/mapserver-4.6.0/mapscript/java
> But I did not have any environment variable like JAVA_HOME
> I tried to produce it:
> /mapscript/java$ JAVA_HOME="/usr/local/jdk1.5.0_03/"
try
export JAVA_HOME="/usr/local/jdk1.5.0_03"
Have you tried with java 1.4.2? That works for sure.
Ciao,
Umberto
> then make
> it gives same errors.
> I am new in java and its installation. I am not sure
> if my java installation is correct.
> I followed debian installation way.
> Later I have java_libs known by
> my system.
> landslide:/home/orkun# cat /etc/ld.so.conf
> /usr/X11R6/lib
> /usr/lib/grass/lib
> /usr/local/jdk1.5.0_03/lib
> mapserver can not still be installed.
> I realized later that I had skipped to sent you history's last values.
> 506 ./ins2 #executable file containing config values
> 507 make clean
> 508 make
> 509 make install
> 510 cd mapscript
> 511 cd java
> 512 make interface
> 513 make *** errors
> 514 history 10
> regards
my last message
thank you
