sld and external graphics
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Wed Jun 22 06:48:25 PDT 2005
Hi There,
Here is a URL using an extrnal graphic :
http://www2.dmsolutions.ca/cgi-bin/mswms_world?SERVICE=WMS&VeRsIoN=1.1.1&Request=GetMap&LAYERS=WorldGen&SLD=http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_polygon_fill_symbol_external.xml
You can see the sld used in this case at :
You should not really do anything special in your map file for this to
be supported. Mapse sure that the external graphic if of Png or Gif format.
Later,
Wendy Arbuckle wrote:
> If anyone uses external graphics by using the sld’s … would it be possible
> to see what you have placed in your “.map” code in order for this to work …
> mine are not coming up
> Thnx so much
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
More information about the MapServer-users
