Single Layer (CGI) call for Legend CHIP
Bart van den Eijnden
bartvde at XS4ALL.NL
Wed Jun 22 14:01:29 EDT 2005
Bob,
have a look at the WMS GetLegendGraphic request. It comes with a parameter
LAYER to specify the layer desired.
Probably something like (by head):
mapserv.exe?map=/mymap.map&service=WMS&version=1.1.1&request=GetLegendGraphic&format=image/png&layer=mylayer
This needs Mapserver 4.4 or later.
If you want separate images for each class in the layer, also specify the
Rule parameter in the GetLegendGraphic request with a reference to the
CLASS NAME you want.
Best regards,
Bart
On Wed, 22 Jun 2005 19:33:38 +0200, Bob Basques
<bob.basques at CI.STPAUL.MN.US> wrote:
> All,
> Is there a way to use to request a single line LEGEND entry from a
> MAPfile without a TEMPLATE?
> We're trying to build a dynamic Layer/Legend and have MapServer build
> the LEGEND Chip from the Mapfile Layer Automatically.
> If I possibly had seperate Map File for each layer, could this be
> accomplished? I suspect that I could then, but then I would need to add
> in the LEGEND parameters for every Mapfile, correct?
> We're really trying to bypass the generation of a complete legend by
> Mapserver and have the generation of the legend items be configured on a
> bylayer request from the CGI.
> Thanks for any input.
> bobb
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
