Single Layer (CGI) call for Legend CHIP
Bob Basques
bob.basques at CI.STPAUL.MN.US
Wed Jun 22 15:08:12 EDT 2005
Jeff McKenna wrote:
>and the latest WMS Server doc has a section on the getlegendgraphic
>request:
>http://mapserver.gis.umn.edu/doc/wms-server-howto.html#getlegendgraphic
Well, I wanted to start using the WMS services anyway . . . . :c)
Thanks for the info (Bart & Jeff).
>jeff
>Bart van den Eijnden wrote:
>>Bob,
>>have a look at the WMS GetLegendGraphic request. It comes with a
>>parameter LAYER to specify the layer desired.
>>Probably something like (by head):
>>mapserv.exe?map=/mymap.map&service=WMS&version=1.1.1&request=GetLegendGraphic&format=image/png&layer=mylayer
>>This needs Mapserver 4.4 or later.
>>If you want separate images for each class in the layer, also specify
>>the Rule parameter in the GetLegendGraphic request with a reference to
>>the CLASS NAME you want.
>>Best regards,
>>Bart
>>On Wed, 22 Jun 2005 19:33:38 +0200, Bob Basques
>><bob.basques at CI.STPAUL.MN.US> wrote:
>>>All,
>>>Is there a way to use to request a single line LEGEND entry from a
>>>MAPfile without a TEMPLATE?
>>>We're trying to build a dynamic Layer/Legend and have MapServer build
>>>the LEGEND Chip from the Mapfile Layer Automatically.
>>>If I possibly had seperate Map File for each layer, could this be
>>>accomplished? I suspect that I could then, but then I would need to add
>>>in the LEGEND parameters for every Mapfile, correct?
>>>We're really trying to bypass the generation of a complete legend by
>>>Mapserver and have the generation of the legend items be configured on a
>>>bylayer request from the CGI.
>>>Thanks for any input.
>>>bobb
