indexed tif images do not display {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Wed Jun 22 19:45:01 EDT 2005
Here is an example
NAME sample
EXTENT 648000 243000 658000 253000
IMAGETYPE png
SHAPEPATH "/home1/www/maps/iv"
FONTSET "/home1/www/maps/iv/fonts.lst"
SYMBOLSET "/home1/www/maps/iv/iv.sym"
UNITS meters
TEMPLATEPATTERN ".*\.html"
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGB # better image quality for photos
EXTENSION "png"
END
WEB
IMAGEPATH "/home1/www/maps/tmp/"
IMAGEURL "/maps/tmp/"
MAXSCALE 100000
# ERROR "/iv/hiba.html"
END
SCALEBAR
IMAGECOLOR 255 255 255
LABEL
COLOR 0 0 0
SIZE TINY
END
STYLE 0
SIZE 350 10
COLOR 0 0 0
OUTLINECOLOR 0 0 0
UNITS METERS
INTERVALS 5
STATUS TRUE
END
REFERENCE
SIZE 200 200
STATUS ON
COLOR -1 -1 -1
MAXBOXSIZE 100
MINBOXSIZE 10
MARKERSIZE 15
MARKER 'circle'
OUTLINECOLOR 255 0 0
END
LEGEND
KEYSIZE 16 12
LABEL
TYPE BITMAP
SIZE SMALL
COLOR 0 0 0
END
STATUS ON
END
QUERYMAP
STATUS ON
# STYLE SELECTED
STYLE HILITE
COLOR 200 0 200
END
LAYER
NAME "2003_030"
GROUP "foto2003"
TILEINDEX "foto/2003_030/tiles"
TILEITEM "Location"
TYPE RASTER
STATUS ON
# MAXSCALE 3500
MINSCALE 199
END
END
And here is the dump of the fist few lines of the tileindex.
The map file is above the "foto" directory.
INFO: Open of `foto/2003_030/tiles.dbf'
using driver `ESRI Shapefile' successful.
Layer name: tiles
Geometry: Polygon
Feature Count: 77
Extent: (651000.000000, 244000.000000) - (656250.000000, 252500.100000)
Layer SRS WKT:
(unknown)
OGRFeature(tiles):0
location (String) = foto/2003_030/65-211-444.tif
POLYGON ((653250.000 252500.100,654000.000 252500.100,654000 252000,653250 252000,653250.000 252500.100))
OGRFeature(tiles):1
location (String) = foto/2003_030/65-212-333.tif
POLYGON ((654000.000 252500.100,654750.000 252500.100,654750 252000,654000 252000,654000.000 252500.100))
OGRFeature(tiles):2
location (String) = foto/2003_030/65-213-222.tif
POLYGON ((653250.000 252000.100,654000.000 252000.100,654000 251500,653250 251500,653250.000 252000.100))
On Wed, 22 Jun 2005, Dennis Megarry wrote:
> Would you happen to have a sample map file showing the usage of a raster tile index?
> Dennis
> ________________________________
> From: UMN MapServer Users List on behalf of Siki Zoltan
> Sent: Wed 6/22/2005 6:06 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] indexed tif images do not display {Scanned}
> Hi,
> You can use relative path, I use relative path to my map file.
> Recently it was discussed on the list, as far as remember you can set
> relative path to the tileindex shape.
> Bye
> Zoltan
> On Wed, 22 Jun 2005, Ethan Alpert wrote:
> > I think you need to rerun gdaltindex. I just did a dbf dump of mine and
> > realized that the paths to the tiles are absolute paths. Not sure if
> > there's a way to construct relative path tileindexes.
> > Anyone?
> > -e
> > -----Original Message-----
> > From: UMN MapServer Users List [mailto:MAPSERVER-USERS at lists.umn.edu] On
> > Behalf Of Yar Doroshenko
> > Sent: Tuesday, June 21, 2005 9:32 PM
> > To: MAPSERVER-USERS at lists.umn.edu
> > Subject: [UMN_MAPSERVER-USERS] indexed tif images do not display
> > Hi Guys,
> > I have created a tile index for my tif images using gdaltindex.
> > Everything works fine on my workstation, I declared a raster in my
> > mapfile. Everything worked great. Next, I copied the tif files, index
> > files and layer definition to my manager's workstation to their
> > corresponding locations. Now, both of the workstations are configured
> > the same way, but my tifs do not display on the manager's workstation.
> > Any piece of advice on what could go wrong?
> > Thank you,
> > Yar
