geographic coordinates don't work
Donlad Harter
harterc1 at COMCAST.NET
Thu Jun 23 19:06:15 EDT 2005
I would like to use geographic coordinates for my main window. My only
layer is georeferenced DRG which uses the UTM projection. It doesn't
work. If I change it and the extents to UTM it does. How can I use
geographic coordinates? I have also noticed that my map file won't work
with the layer status "on". It has to be "default"
Here is most of my map file.:
MAP
NAME test3
IMAGETYPE png
#EXTENT 578853 3857452.040 592267.160 3875770.440
EXTENT -86.125 34.875 -86 35 SIZE 1000 600
SHAPEPATH "/var/www/html/data/topo"
SYMBOLSET "tutorial/symbols/symbols35.sym"
FONTSET "tutorial/fonts/fonts.list"
WEB
TEMPLATE 'test3_template.html'
IMAGEPATH '/var/www/html/tmp/'
IMAGEURL '/tmp/'
MINSCALE 10000
MAXSCALE 250000
END
PROJECTION
"proj=latlong"
# "proj=utm"
"ellps=clrk66"
# "zone=16"
# "north" END
# Start of LAYER DEFINITIONS ---------------------------------------------
LAYER # raster layer begins here
NAME N_AL
STATUS DEFAULT TILEINDEX "al_index.shp"
TILEITEM "Location"
TYPE RASTER
SIZEUNITS meters
PROJECTION
"proj=utm"
"ellps=clrk66"
"zone=16"
"north" END
END # raster layer ends here
# End of LAYER DEFINITIONS -------------------------------
