WMS server - legend graphic/symbology
Bart van den Eijnden
BEN at SYNCERA-ITSOLUTIONS.NL
Fri Jun 24 10:48:29 EDT 2005
You always need to add a NAME to the CLASS which you want Mapserver to show in the legend.
Not sure if this will get you through showing the legend in ArcMap though. Try and log the request that ArcMap is sending.
Does Mapserver put a LegendURL in your WMS capabilities and does it work? I am assuming ArcMap will use that for input.
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> Kevin Grootendorst <kgrootendorst at BAIRD.COM> 06/24/05 04:44pm >>>
I have a map file which I'm setting up as a WMS server, so that I can view
my data in ArcMap 9.
I'm successful in viewing the WMS in ArcMap, however it does not contain a
graphic in the legend. In other words, the layers draw correctly (with
same colors as in the map file), but the legend does not indicate any
symbology.
Any ideas how I can get the legend symbology to show?
Using MS 4.4 on win2000.
Below is a snippet from my .map file:
(web definition:)
WEB
IMAGEPATH "C:/web/ms_tmp/"
IMAGEURL "/ms_tmp/"
METADATA
"wms_title" "Pelee WMS"
"wms_onlineresource" "http://maps.baird.com/cgi-bin/mapserv.exe?
map=/web/maplab-2.2/Pelee/Pelee.map&"
"wms_srs" "EPSG:26917"
"wms_abstract" "Pelee WMS server"
"wms_style" ""
END
END # END OF WEB SECTION
(layer definition):
LAYER
#NAME "Municipalities (coarse)"
NAME "Municipalities_coarse"
GROUP "BASE"
METADATA
"wms_title" "Municipalities"
"wms_style" ""
"wms_group_title" "base"
END
STATUS on
DATA "./Municipalities"
TYPE POLYGON
UNITS METERS
TEMPLATE "ttt"
SIZEUNITS PIXELS
TOLERANCE 0
TOLERANCEUNITS PIXELS
LABELITEM "NAME"
CLASS
LABEL
TYPE BITMAP
SIZE tiny
POSITION cc
OFFSET 0 0
COLOR 100 100 100
#SHADOWSIZE 1 1
OUTLINECOLOR 255 255 255
END
STYLE
SYMBOL 8
OUTLINECOLOR 0 0 0
BACKGROUNDCOLOR 99 99 99
SIZE 2
END
END
END
