file size issue
Lowell Filak
lfilak at MEDINACO.ORG
Fri Jun 24 14:39:33 EDT 2005
The following message was sent by Jerl Simpson <jerl.simpso at GMAIL.COM>
on Mon, 20 Jun 2005 08:37:29 -0500.
> That's the same conclusion I came to as well. I thought I could
> either use the C API or I could use the tile index files. They are
> all broken up into smaller files. The issue with that is I would have
> to modify the shp2mysql.pl file so it did not create a new table in
> the database for each file of the tiling.
> Thanks again,
> Jerl
> > Jerl,
> > I think I may have missed something. If my understanding (from a
> > conference session today) is correct the problem lies in GEO::Shapelib
> > itself. It appears that it reads the geometries into an array which
> > would still mean you would need enough ram to read the entire shapefile.
> > The only workaround is to use shapelib via C directly instead of through
> > the perl module. From C you would be able to iterate over each entity.
Jerl,
There is 1 last option if you would like to create an arrays.i include
file for swig'ng shapelib.
What I have currently is a swig'd version of shapelib that sort-of
works. The geometry data is extracted from the shape into a few C arrays
and there is a typemap required to make those available as perl arrays,
otherwise they show up as _p_double=SCALAR(0x...) and are unuseable.
Lowell
