[NEWBIE] Using Mapserver and PROJECTION
Frank Warmerdam
fwarmerdam at GMAIL.COM
Sun Jun 26 11:48:57 EDT 2005
On 6/26/05, François TOURDE <fr-ms at tourde.org> wrote:
> Hi the list.
> I'm a newbie using mapserver, and in geodata. :( ... I've a probably
> simple problem using the image output:
> On my .MAP file, I have the following lines:
> # Mode latlong
> EXTENT 2.8830 42.683 7.5 43.950 # Geographic
> PROJECTION "init=epsg:4326" END
> UNITS DD
> All my layers have no PROJECTION infos.
> When I replace the above lines by:
> # mode Collignon
> EXTENT 205512.50 4889370.83 521106.75 5051672.48
> PROJECTION
> "proj=collg"
> END
> UNITS METERS
> the image is ... blank. No coast lines, no features, etc...
> Could you point me the problem?
François,
It could be a number of things, but your bounds do seem reasonable.
I would suggest adding an explicit ellipse definition:
PROJECTION
"proj=collg"
"ellps=WGS84"
END
Use normal debugging techniques. For instance, check
your error log, try rendering with shp2img, as that can provide
better feedback. Turn on debugging. etc.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
