Plot 'free' text on a map
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Sun Jun 26 14:54:49 EDT 2005
Hoeven, Maarten van der wrote:
> Hi list,
> using Mapserver 4.6.0, PHP Mapscript: is it possible to write text to a map? I.e., not connected to any shape,layer, whatsoever, but just something like plotting a text-string somehwere on the map, for example a title in the top of the map, and a copyright/datestamp at the bottom of the map.
> Is this possible?
> Thanks for all your previous help; most helpful!
Here is the layer I use, should work for any label in pixel x,y, you'll
have to figure out how to place it in map x,y:
LAYER
NAME "copyright"
STATUS DEFAULT
TYPE POINT
TRANSFORM OFF
FEATURE
POINTS
0 1
END
END
CLASS
COLOR 0 0 0
TEXT "Copyright © 2005, Stephen Woodbridge"
LABEL
TYPE TRUETYPE
FONT "arial"
SIZE 7
POSITION LR
OFFSET 0 0
BUFFER 2
COLOR 0 0 0
BACKGROUNDCOLOR 254 254 225
FORCE TRUE
END
END
END
