Mapscript/Java Tomcat
a j
sc0rp10nau at YAHOO.COM.AU
Sun Jun 26 23:08:53 EDT 2005
Hi all,
I've been stuck with a problem for a couple of days
now, and i desperately need any help that I can get.
I've successfully got a map image with some dynamic
points using a simple desktop app. Basically this
small app statically loads the mapscript library,
reads in a map file, adds a couple of points and save
the result image to the disk.
Now when I do this exact same thing as a Servlet, I
just get the java.lang.UnsatisfiedLinkError:
c:\mapserver\mapscript.dll: Can't find dependent
libraries.
I'm using Tomcat 5.5.9, Java 1.5, and MapServer 4.4 on
a windows machine. I've set the CLASSPATH and PATH
variables already. I've set the java.library.path to
c:\mapserver but it fails to load the library (or its
dependencies) properly. Here is the top part of the
error:
==== start error ====
C:\mapserver\mapscript.dll: Can't find dependent
libraries
at java.lang.ClassLoader$NativeLibrary.load(Native
Method)
at java.lang.ClassLoader.loadLibrary0(Unknown Source)
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.loadLibrary0(Unknown Source)
at java.lang.System.loadLibrary(Unknown Source)
==== end error ====
This is what i do in the servlet:
==== start code =====
import javax.servlet.*;
import javax.servlet.http.*;
import edu.umn.gis.mapscript.*;
public class MapServer extends HttpServlet {
static
try
System.loadLibrary("mapscript");
System.out.println("Loaded the Mapscript library");
catch (UnsatisfiedLinkError e)
e.printStackTrace(System.out);
protected void processRequest(HttpServletRequest
request, HttpServletResponse response)
throws ServletException, IOException {
// do something with the mapObj, etc..
// mapObj map = new mapObj("path/to/map/file.map");
==== end code ====
As mentioned before, any help with this would be
great, and it is quite urgent, as my deadlines are
approaching.
tia.
Ajay
Send instant messages to your online friends http://au.messenger.yahoo.com
