WMS server - legend graphic/symbology
Kevin Grootendorst kgrootendorst at BAIRD.COM
Mon Jun 27 10:24:46 PDT 2005
Bonnie,
Thanks for the suggestion - but it doesn't fix the problem.  The WMS server
will come in 'unchecked', but all of the actual WMS layers are still
checked.
Thanks anyways.
Kevin
On Mon, 27 Jun 2005 08:03:38 +0800, Bonnie Stewart
<Bonnie.Stewart at DLI.WA.GOV.AU> wrote:
>Hi Kevin,
>In ArcMap, there's an option "Make newly added layers visible by default",
under Tools -> Options -> General tab.
>I think this is why the layers are always on - if I remember correctly, it
turns on the first 20 layers when you connect to a WMS.
>Try unchecking this option and see if that fixes the problem.
>Cheers,
>Bonnie
>__________________________________
>Bonnie Stewart
>Research Officer
>Satellite Remote Sensing Services
>Information Access Division
>Department of Land Information
>65 Brockway Road, FLOREAT WA 6014
>Ph. (08) 9387 0342 | Fx. (08) 9383 7142
>bonnie.stewart at dli.wa.gov.au
>www.dli.wa.gov.au
>From: UMN MapServer Users List on behalf of Kevin Grootendorst
>Sent: Fri 24/06/2005 11:00 PM
>To: MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: [Maybe SPAM] Re: [UMN_MAPSERVER-USERS] WMS server - legend
graphic/symbology
>Bart,
>Thanks for your suggestion.
>I added NAME " " to the CLASS object and everything works as expected.
>Do you know why ALL the wms layers would be turned 'on' while viewing in
>ArcMap?  I assumed that only the layers with STATUS ON would be visible
>initially.
>The log that ArcMap sends is as follows:
>"GET /cgi-bin/mapserv.exe?map=/web/maplab-
>2.2/Pelee/Pelee.map&VERSION=1.1.1&REQUEST=GetMap&SRS=EPSG:26917&BBOX=298978
>084774465,4606186.14109543,512740.303618177,4785860.76331283&WIDTH=972&HEIG
H
>T=817&LAYERS=Municipalities_coarse,Cities&STYLES=&EXCEPTIONS=application/vn
d
>.ogc.se_xml&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE HTTP/1.1"
>200 53798
>The 'cities' layer is set to Status OFF, but still draws when the service
>is first added to ArcMap.
>Kevin
>On Fri, 24 Jun 2005 16:48:29 +0200, Bart van den Eijnden <BEN at SYNCERA-
>ITSOLUTIONS.NL> wrote:
>>You always need to add a NAME to the CLASS which you want Mapserver to
>show in the legend.
>>Not sure if this will get you through showing the legend in ArcMap though.
>Try and log the request that ArcMap is sending.
>>Does Mapserver put a LegendURL in your WMS capabilities and does it work?
>I am assuming ArcMap will use that for input.
>>Best regards,
>>Bart
>>Syncera IT Solutions
>>Postbus 270
>>2600 AG  DELFT
>>tel.nr.: 015-7512436
>>email: BEN at Syncera-ITSolutions.nl
>>>>> Kevin Grootendorst <kgrootendorst at BAIRD.COM> 06/24/05 04:44pm >>>
>>Hi,
>>I have a map file which I'm setting up as a WMS server, so that I can view
>>my data in ArcMap 9.
>>I'm successful in viewing the WMS in ArcMap, however it does not contain a
>>graphic in the legend.  In other words, the layers draw correctly (with
>>same colors as in the map file), but the legend does not indicate any
>>symbology.
>>Any ideas how I can get the legend symbology to show?
>>Using MS 4.4 on win2000.
>>Below is a snippet from my .map file:
>>(web definition:)
>>WEB
>>    IMAGEPATH "C:/web/ms_tmp/"
>>    IMAGEURL "/ms_tmp/"
>>  METADATA
>>     "wms_title" "Pelee WMS"
>>     "wms_onlineresource" "http://maps.baird.com/cgi-bin/mapserv.exe?
>>map=/web/maplab-2.2/Pelee/Pelee.map&"
>>     "wms_srs" "EPSG:26917"
>>     "wms_abstract" "Pelee WMS server"
>>            "wms_style" ""
>>   END
>>  END # END OF WEB SECTION
>>(layer definition):
>>LAYER
>>    #NAME "Municipalities (coarse)"
>>    NAME "Municipalities_coarse"
>>    GROUP "BASE"
>>    METADATA
>> "wms_title" "Municipalities"
>> "wms_style" ""
>>        "wms_group_title"  "base"
>>    END
>>    STATUS on
>>    DATA "./Municipalities"
>>    TYPE POLYGON
>>    UNITS METERS
>>    TEMPLATE "ttt"
>>    SIZEUNITS PIXELS
>>    TOLERANCE 0
>>    TOLERANCEUNITS PIXELS
>>    LABELITEM "NAME"
>>    CLASS
>>    LABEL
>>        TYPE BITMAP
>>        SIZE tiny
>>        POSITION cc
>>        OFFSET 0 0
>>        COLOR 100 100 100
>>        #SHADOWSIZE 1 1
>> OUTLINECOLOR 255 255 255
>>      END
>>      STYLE
>>        SYMBOL 8
>>        OUTLINECOLOR 0 0 0
>>        BACKGROUNDCOLOR 99 99 99
>>        SIZE 2
>>      END
>>    END
>>  END
>This e-mail and any files transmitted with it are intended only for the
use of the addressee(s).  It may contain information that is confidential
and privileged.  If you are not an intended recipient, any use,
interference with, disclosure, distribution or copying of this material is
unauthorised and prohibited. If you receive this in error, please notify
the author by Return email to the sender. Information in this message not
relating to the official business of DLI shall be understood as neither
given nor endorsed by it.  While every care is taken, it is recommended
that you scan any attachments for viruses. DLI liability is limited to re-
supplying affected attachments.
More information about the MapServer-users mailing list
