Mapscript/Java Tomcat
Ajay Ranipeta sc0rp10nau at YAHOO.COM.AU
Tue Jun 28 05:33:26 PDT 2005
Umberto,
Mate you are a legend. All worked like a charm. What actually happend was I
use netBeans for java dev work. And I forgot that i've had a few libraries
lying around there. Combined with a couple of entries in the system env
variables that i didn't really realise.
It all works now, so thanks again.
cheers,
Ajay
On Tue, 28 Jun 2005 10:25:21 +0200, Umberto Nicoletti
<umberto.nicoletti at GMAIL.COM> wrote:
>I think at this point you should start over with a clean setup.
>The steps I would do are:
>0) clean up windows: remove old installs of mapserver and system32
>libraries from this install. Start with a fresh system if you can
>1) clean the environment from all possible references to
>mapserver/gdal/etc libraries
>2) create a c:\mapserver directory and copy all mapserver dlls in there
>3) add a **system** (not user!!) PATH entry to c:\mapserver
>4) if you can run the java mapscript tests (make test in mapscript/java)
>4) install java and tomcat and make sure they work
>5) install the webapp and dependent jars/classes in shared/lib and
>shared/classes. Please note that as of recent versions of mapscript
>the native library is loaded by mapscript.jar already, so there is no
>need to provide a static method
>6) edit catalina.bat and add -D java.library.path=c:\mapserver
>7) run tomcat
>NOTE to item 3: env variables in windows have always been a mess as
>system services could not pivk them up. If you suspect this is
>happening try to start tomcat as your user (run startup.bat) and see
>if it makes any difference.
>Then cross fingers...
>Ciao,
>Umberto
>On 6/28/05, Ajay Ranipeta <sc0rp10nau at yahoo.com.au> wrote:
>> Hi Umberto,
>> I've already done that. It still doesn't fix the problem. I've even followed
>> Daniel Caldeweyher's How-to on Tomcat 5.5
>> (http://ms.gis.umn.edu/docs/howto/java_mapscript_Tomcat_55/view) and that
>> hasn't helped much either.
>> Any idea's?
>> btw, I've even copied the nad directory to the system32 as well. I've used
>> ListDLL's app from SysInternals, to check what dll's are being loaded, and
>> they seem consistent with the desktop test app that i've done. So the only
>> thing i can think of is the map file not being loaded properly or found. But
>> i'm sure it should throw an IOException.
>> I've seriously am out of ideas, and seriously losing my hair over this.
>> Hope you guys can help.
>> Cheers,
>> Ajay
>> On Mon, 27 Jun 2005 14:31:19 +0200, Umberto Nicoletti
>> >Remove mapscript.jar from your app WEB-INF/lib and put it in
>> >TOMCAT_HOME/common/lib.
>> >If I recall correctly 4.4.2 should have the native library loading
>> >code already in place in  mapscript.jar so you do not have to call
>> >System.loadLibrary() for your servlet.
>> >Regards,
>> >Umberto
>> >On 6/27/05, Ajay Ranipeta <sc0rp10nau at yahoo.com.au> wrote:
>> >> Hi Umberto,
>> >> Thx for the quick response. I've set the directory in the PATH
variable, as
>> >> well as the CLASSPATH (thought this might help). I've pretty much run
out of
>> >> ideas and this list is my last resort.  As mentioned before, wierd
thing is,
>> >> it works fine as a standalone app, just not as a web-app under tomcat.
>> >> Now, I've followed your suggestion, and copied all the dll files (from
>> >> hobu's 4.4.2 zip file) to the system32 folder. Now this has been a bit
of a
>> >> progress. Checking the tomcat log files, it says it has loaded the dll
>> >> successfully (got this from a System.out statement after the loadLibrary
>> >> statement). Now the next step, creating a map object (mapObj map = new
>> >> mapObj("path/to/map/file.map") ) throws the following error:
>> >> === start error ===
>> >> java.lang.UnsatisfiedLinkError: new_mapObj
>> >>  edu.umn.gis.mapscript.mapscriptJNI.new_mapObj(Native Method)
>> >>  edu.umn.gis.mapscript.mapObj.<init>(mapObj.java:332)
>> >> === end error ===
>> >> Any ideas?
>> >> cheers,
>> >> AJ
More information about the MapServer-users mailing list
