Mapscript/cloneMap/Processing
Sean Gillies
sgillies at FRII.COM
Tue Jun 28 07:31:55 PDT 2005
On Jun 28, 2005, at 6:14 AM, Benedikt Rothe wrote:
> Dies ist eine mehrteilige Nachricht im MIME-Format.
> --=_alternative 00433F71C125702E_=
> Content-Type: text/plain; charset="US-ASCII"
> Hallo List
> We are using MapScript/Java inside Tomcat.
> We encountered a crash in webObj.cloneMap() when
> a PROCESSING-statement was used inside a Layer-Block.
> My impression is, that there is a bug in mapcopy.c/msCopyLayer (?)
> I think: After the line
> MS_COPYSTELEM(numprocessing);
> and before the loop
> for (i = 0; i < dst->numprocessing; i++) {...}
> a memory-allocation for dst->processing is missing.
> I made a change:
> MS_COPYSTELEM(numprocessing); //OLD
> // Allocating an initializing memory for processing-array.
> // Must be dst->numprocessing+1 to be 0-terminated.
> dst->processing = numprocessing ?
> (char*)
> calloc(dst->numprocessing+1,sizeof(char*)) :
> 0;
> for (i = 0; i < dst->numprocessing; i++) { //OLD
> I hope this is helpful. Greetings
> Benedikt Rothe
Hi Benedikt,
If you will enter a new issue in our tracker
http://mapserver.gis.umn.edu/bugs/enter_bug.cgi
under the MapServer C Library component, and assign it to
sgillies at frii.com, I will fix this right away.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://zcologia.com
More information about the MapServer-users
