Antwort: Re: [UMN_MAPSERVER-USERS] Antwort: Re: [UMN_MAPSERVER-USERS] Bug in msCopy
    Benedikt Rothe
    umn-ms at HYDROTEC.DE
    Wed Jun 29 03:22:31 PDT 2005
Thank's Umberto. I did not know -Xloggc before.
As far as I understood -Xloggc measures the memory allocated by the JVM.
And this is the kind of memory which is not hazardous ...
Anyway I will look in this direction...
Benedikt
Umberto Nicoletti <umberto.nicoletti at gmail.com> schrieb am 29.06.2005
12:10:03:
> On 6/29/05, Benedikt Rothe <umn-ms at hydrotec.de> wrote:
> > Hello Umberto
> > Thank you for yout hint's!
> > You are right: One should be cautios. But for the moment I have the
> > impression
> > that we seeme to have found a way, which don't raise obvious errors in
the
> > first
> > moment :-)
> > After the mentioned changes in mapcopy.c the approache
> > (TomCat/MapScript/Connection-Pooling/MapCloning) seeme to
> > work for us. (Working with Version 4.6)
> > But:
> > - We do need some more stress-testing.(We already made automated
> >   http-requests from a Java-Programs. But this was definitly not
enough and
> >   not "nasty" enough!)
> jmeter is an excellent tool for stress/load testing (
> jakarta.apache.org/jmeter/ )
> > - New problems could raise, if more or other features from
> > mapserver/mapscript
> >   are used then we actualy do.
> > - Memory footprint of the running-tomcat has to be watched!. What
about the
> > size
> >    of the application after 100, 500, 600, 800 ... requests? (I'm not
quite
> > shure how to do this!
> Use the -Xloggc:/tmp/gc.log to java when starting tomcat and then run
> the stress tests. You should be able to see that if memory get
> correctly garbage collected the avail mem is almost always equal to a
> certain initial size.
> Warning: this is not 100% error proof, but it should be start. try
googling...
> Ciao,
> Umberto
> >    Watching Java-Programs is difficult because of garbage-collections
> > Greetings
> > Benedikt
> > 11:03:46:
> >  > > Dear List
> >  > > We are using MapScript/Tomcat/Java/OracleSpatial.
> >  > > We use mapObj.mapClone() to get a fresh mapObject
> >  > > in each request without reading the Mapfile.
> >  > Benedikt,
> >  > I would not do that (tm). In my apps I recreate a fresh mapObj with
> >  > each request  as the overhead is mininum and the benefits high (so
> >  > that the ratio is in favor of this approach).
> >  > Besides this is the only known method to work (as far as I know)
and
> >  > this stems from the fact that mapserver was in the beginning (and
> >  > still is, with improvements) a CGI. As you might know cgis are
> >  > processes that are created by the web server to serve a single
request
> >  > and then exit, so memory cleanup and thread safety are non-issues
for
> >  > them.
> >  > Even in php mapscript php must be used as a cgi (instead of a DSO)
to
> >  > make sure that it works.
> >  > > We detected problems after we activated Connection-Pooling:
> >  > > Tomcat crashed in mapObj.delete()
> >  > I would not use connection pooling just because it will not work
> >  > reliably with Java Servlets for the reasons explained above.
> >  > This matter (connection pooling and map cloning) surely requires
> >  > deeper investigation, one of the developers coul step in to give
his
> >  > opinion on my statements (which I would sincerely hope were false,
but
> >  > fear not). Btw, I seem to recall that the above issues (long lived
> >  > instance against per request instance)  were already discussed on
the
> >  > list before.
> >  > Best regards,
> >  > Umberto
> >  > > Hole thing turned out to be a bug in mapcopy.c where
> >  > > the joins are copied:
> >  > > MS_COPYSTELEM(numjoins);
> >  > > for (i = 0; i < dst->numprocessing; i++) {
> >  > >    return_value = msCopyJoin(&(dst->joins[i]), &(src->joins[i]));
> >  > > This must be changed to
> >  > > for (i = 0; i < dst->numjoins; i++) {
> >  > > There is some other code in mapobject.c, wich didn't
> >  > > raise any problems for us, but from wich I do think
> >  > > that array-allocs are missing.
> >  > > I watched the code an *think* these are are not allocated
> >  > > anywhere. I hope, there is no misleading hint:
> >  > >  // I do think, that dst->point is not allocated.
> >  > >  // code seems to be unused (?)
> >  > >  dst->numpoints = src->numpoints;
> >  > >  for (i = 0; i < dst->numpoints; i++) {
> >  > >   MS_COPYPOINT(&(dst->point[i]), &(src->point[i]));
> >  > >  // I do think, that dst->items and dst->values is
> >  > >  // not allocated
> >  > >  MS_COPYSTELEM(numitems);
> >  > >  for (i = 0; i < dst->numitems; i++) {
> >  > >   MS_COPYSTRING(dst->items[i], src->items[i]);
> >  > >   MS_COPYSTRING(dst->values[i], src->values[i]);
> >  > >  // I'm quite shure, that dst->items is not allocated
> >  > > I hope this is helpful. Greetings
> >  > > Benedikt Rothe
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050629/323df4e8/attachment.htm>
More information about the MapServer-users
