Bug in msCopy
Benedikt Rothe
umn-ms at HYDROTEC.DE
Wed Jun 29 07:26:28 PDT 2005
hi frank
i did it -> bug 1403
bye
benedikt
Frank Warmerdam <fwarmerdam at gmail.com> schrieb am 29.06.2005 16:16:16:
> On 6/29/05, Benedikt Rothe <umn-ms at hydrotec.de> wrote:
> > Dear List
> > We are using MapScript/Tomcat/Java/OracleSpatial.
> > We use mapObj.mapClone() to get a fresh mapObject
> > in each request without reading the Mapfile.
> > We detected problems after we activated Connection-Pooling:
> > Tomcat crashed in mapObj.delete()
> > Hole thing turned out to be a bug in mapcopy.c where
> > the joins are copied:
> > MS_COPYSTELEM(numjoins);
> > for (i = 0; i < dst->numprocessing; i++) {
> > return_value = msCopyJoin(&(dst->joins[i]), &(src->joins[i]));
> > This must be changed to
> > for (i = 0; i < dst->numjoins; i++) {
> > There is some other code in mapobject.c, wich didn't
> > raise any problems for us, but from wich I do think
> > that array-allocs are missing.
> > I watched the code an *think* these are are not allocated
> > anywhere. I hope, there is no misleading hint:
> Benedikt,
> I would encourage you to submit this via bugzilla,
> and ensure it gets assigned to Sean Gilles who
> takes care of map cloning problems.
> The cloning is a bit prone to bugs, but we want to fix it
> up.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050629/ea940c8c/attachment.htm>
More information about the MapServer-users
