Is your dbname really dbpotgis and not dbpostgis?
Ezequias
Rodrigues da
Rocha To
<ezequias at RECIFE. MAPSERVER-USERS at LISTS.UMN.EDU
PE.GOV.BR> cc
Sent by: UMN
MapServer Users Subject
List [UMN_MAPSERVER-USERS] Postgis
<MAPSERVER-USERS@ Connection
LISTS.UMN.EDU>
06/30/2005 12:09
PM
Please respond to
Ezequias
Rodrigues da
Rocha
PE.GOV.BR>
I am trying to load a mapserver service with a postgis connection but the
MS reported this message below:
msDrawMap(): Image handling error. Failed to draw layer named 'bairros'.
msPOSTGISLayerOpen(): Query error. couldnt make connection to DB with
connect string 'user=postgres password=post dbname=dbpotgis
host=196.168.0.15 port=5432'.
Error reported was 'could not create socket: Permission denied '.
This error occured when trying to make a connection to the specified
postgresql server.
Most commonly this is caused by
(1) incorrect connection string
(2) you didnt specify a 'user=...' in your connection string
(3) the postmaster (postgresql server) isnt running
(4) you are not allowing TCP/IP connection to the postmaster
(5) your postmaster is not running on the correct port - if its not on
5432 you must specify a 'port=...'
(6) the security on your system does not allow the webserver (usually user
'nobody') to make socket connections to the postmaster
(7) you forgot to specify a 'host=...' if the postmaster is on a different
machine
(8) you made a typo
Does anyone can tell me what to do ?
Atenciosamente (Sincerely)
Ezequias Rodrigues da Rocha
* www.recife.pe.gov.br
A pior das democracias ainda é melhor do que a melhor das ditaduras
The worst of democracies is still better than the better of dictatorships
(Embedded image moved to file: pic18756.jpg) MSN Messenger:
ezequias at hotmail.com
(Embedded image moved to file: pic11840.gif)Add FUN to your email - CLICK
HERE!
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050630/6aafd905/attachment.jpg>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050630/6aafd905/attachment.gif>
