mapserv segfaults trying to get thequery results of a native
oracle spati
Bart van den Eijnden
BEN at SYNCERA-ITSOLUTIONS.NL
Mon May 2 05:23:02 EDT 2005
Hi Nicol,
I have had similar crashes on Windows which were solved magically by compiling with Visual Studio 7 instead of 6. But for Fernando a similar situation on Linux worked fine.
Can you try the following data statement as a last resort:
DATA "GEOMETRIE from (SELECT ID, GEOMETRIE FROM FLURST) USING UNIQUE ID SRID 82027"
That used to work for me on Windows even with Visual Studio 6, but then you miss a lot of attribute info ofcourse.
Probably Fernando needs to step in and help, but in Brazil it is still quite early I guess :-)
Best regards,
Bart
Syncera-ITSolutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> Nicol Hermann <mapserver at geoworld.de> 05/02/05 11:17am >>>
Hi Bart, Fernando, List
thank you for your mail.
I changed the DATA statement according to your advice.
The statement is:
DATA "GEOMETRIE from (SELECT * FROM FLURST) USING UNIQUE ID SRID 82027"
Sadly this changes nothing. I further get a segfault.
Attached the new gdb output:
nicol at emil:~/public_html/mapserver/dev$ gdb php
GNU gdb 6.3-debian
Copyright 2004 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you
are
welcome to change it and/or distribute copies of it under certain
conditions.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB. Type "show warranty" for
details.
This GDB was configured as "i386-linux"...Using host libthread_db
library "/lib/libthread_db.so.1".
(gdb) run nativ_oraclequelle_query.php
Starting program: /usr/local/bin/php nativ_oraclequelle_query.php
[Thread debugging using libthread_db enabled]
[New Thread 16384 (LWP 8349)]
Content-type: text/html
X-Powered-By: PHP/4.3.8
ms_map_obj Object
[_handle_] => Resource id #1
[numlayers] => 1
[name] => Karte
[status] => 1
[debug] => 0
[width] => 300
[height] => 300
[maxsize] => 2048
[transparent] => 0
[interlace] => 0
[imagetype] =>
[imagequality] => 0
[extent] => ms_rect_obj Object
[_handle_] => Resource id #2
[minx] => 0
[miny] => 0
[maxx] => 0
[maxy] => 0
[cellsize] => 0
[units] => 0
[scale] => 0
[resolution] => 0
[shapepath] =>
[keysizex] => 0
[keysizey] => 0
[keyspacingx] => 0
[keyspacingy] => 0
[symbolsetfilename] =>
[fontsetfilename] =>
[mappath] =>
[imagecolor] => ms_color_obj Object
[_handle_] => Resource id #3
[red] => 0
[green] => 0
[blue] => 0
[web] => ms_web_obj Object
[_handle_] => Resource id #4
[log] =>
[imagepath] =>
[template] =>
[imageurl] =>
[header] =>
[footer] =>
[empty] =>
[error] =>
[mintemplate] =>
[maxtemplate] =>
[minscale] => 0
[maxscale] => 0
[queryformat] =>
[_handle_] => Resource id #5
[minx] => 0
[miny] => 0
[maxx] => 0
[maxy] => 0
[reference] => ms_reference_obj Object
[_handle_] => Resource id #6
[image] =>
[width] => 0
[height] => 0
[status] => 0
[_handle_] => Resource id #7
[minx] => 0
[miny] => 0
[maxx] => 0
[maxy] => 0
[color] => ms_color_obj Object
[_handle_] => Resource id #8
[red] => 0
[green] => 0
[blue] => 0
[outlinecolor] => ms_color_obj Object
[_handle_] => Resource id #9
[red] => 0
[green] => 0
[blue] => 0
[scalebar] => ms_scalebar_obj Object
[_handle_] => Resource id #10
[height] => 0
[width] => 0
[style] => 0
[intervals] => 0
[units] => 0
[status] => 0
[position] => 0
[transparent] => 0
[interlace] => 0
[postlabelcache] => 0
[label] => ms_label_obj Object
[_handle_] => Resource id #11
[font] =>
[encoding] =>
[type] => 0
[shadowsizex] => 0
[shadowsizey] => 0
[backgroundshadowsizex] => 0
[backgroundshadowsizey] => 0
[size] => 0
[minsize] => 0
[maxsize] => 0
[position] => 0
[offsetx] => 0
[offsety] => 0
[angle] => 0
[autoangle] => 0
[buffer] => 0
[antialias] => 0
[wrap] => 0
[minfeaturesize] => 0
[autominfeaturesize] => 0
[mindistance] => 0
[partials] => 0
[force] => 0
[_handle_] => Resource id #12
[red] => 0
[green] => 0
[blue] => 0
[_handle_] => Resource id #13
[red] => 0
[green] => 0
[blue] => 0
[shadowcolor] => ms_color_obj Object
[_handle_] => Resource id #14
[red] => 0
[green] => 0
[blue] => 0
[backgroundcolor] => ms_color_obj Object
[_handle_] => Resource id #15
[red] => 0
[green] => 0
[blue] => 0
[backgroundshadowcolor] => ms_color_obj Object
[_handle_] => Resource id #16
[red] => 0
[green] => 0
[blue] => 0
[_handle_] => Resource id #17
[red] => 0
[green] => 0
[blue] => 0
[_handle_] => Resource id #18
[red] => 0
[green] => 0
[blue] => 0
[_handle_] => Resource id #19
[red] => 0
[green] => 0
[blue] => 0
[_handle_] => Resource id #20
[red] => 0
[green] => 0
[blue] => 0
[legend] => ms_legend_obj Object
[_handle_] => Resource id #21
[height] => 0
[width] => 0
[keysizex] => 0
[keysizey] => 0
[keyspacingx] => 0
[keyspacingy] => 0
[status] => 0
[position] => 0
[transparent] => 0
[interlace] => 0
[template] =>
[_handle_] => Resource id #22
[font] =>
[encoding] =>
[type] => 0
[shadowsizex] => 0
[shadowsizey] => 0
[size] => 0
[minsize] => 0
[maxsize] => 0
[position] => 0
[offsetx] => 0
[offsety] => 0
[angle] => 0
[autoangle] => 0
[buffer] => 0
[antialias] => 0
[wrap] => 0
[mindistance] => 0
[partials] => 0
[force] => 0
[_handle_] => Resource id #23
[red] => 0
[green] => 0
[blue] => 0
[_handle_] => Resource id #24
[red] => 0
[green] => 0
[blue] => 0
[_handle_] => Resource id #25
[red] => 0
[green] => 0
[blue] => 0
[_handle_] => Resource id #26
[red] => 0
[green] => 0
[blue] => 0
[_handle_] => Resource id #27
[red] => 0
[green] => 0
[blue] => 0
[_handle_] => Resource id #28
[red] => 0
[green] => 0
[blue] => 0
[_handle_] => Resource id #29
[red] => 0
[green] => 0
[blue] => 0
[latlon] => ms_projection_obj Object
[_handle_] => Resource id #30
[outputformat] =>
[labelcache] => ms_labelcache_obj Object
[_handle_] => Resource id #31
[Mon May 2 11:07:01 2005].683777 msOracleSpatialLayerOpen called with:
[Mon May 2 11:07:01 2005].846399 msOracleSpatialLayerOpen. Shared
connection not available. Creating one.
[Mon May 2 11:07:01 2005].846593
msConnPoolRegister(Oracle,user/passwd at BOX.os,0x82bcd98)
[Mon May 2 11:07:01 2005].853183 msOracleSpatialLayerFreeItemInfo was
called.
[Mon May 2 11:07:01 2005].882663 msOracleSpatialLayerWhichShapes was
called.
[Mon May 2 11:07:01 2005].888674 msOracleSpatialLayerWhichShapes. Using
this Sql to retrieve the data: SELECT ID, GEOMETRIE FROM (SELECT * FROM
FLURST) WHERE SDO_FILTER( GEOMETRIE, MDSYS.SDO_GEOMETRY(2003, 82027,
NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO_ORDINATE_ARRAY(3384094.22,5499947.53,3427070.22,5542923.53) ),'querytype=window') = 'TRUE'
[Mon May 2 11:07:23 2005].259709 msOracleSpatialLayerFreeItemInfo was
called.
[Mon May 2 11:07:23 2005].259903 msOracleSpatialLayerClose was called.
Layer connection: user/passwd at BOX.os
[Mon May 2 11:07:23 2005].259978 msOracleSpatialLayerClose. Cleaning
layerinfo handlers.
[Mon May 2 11:07:23 2005].260121 msOracleSpatialLayerClose. Cleaning
Oracle handlers.
[Mon May 2 11:07:23 2005].260214
msConnPoolRelease(Oracle,user/passwd at BOX.os,0x82bcd98)
[Mon May 2 11:07:23 2005].260293
msConnPoolClose(user/passwd at BOX.os,0x82bcd98)
<IMG SRC=/~nicol/mapserver/phpmapserver/tmp/111502482183491.gif>
<p>Anzahl der Layer: 1 - Anzahl der Klassen dieses Layers: [Mon May 2
11:07:23 2005].372014 msOracleSpatialLayerOpen called with: GEOMETRIE
[Mon May 2 11:07:23 2005].449381 msOracleSpatialLayerOpen. Shared
[Mon May 2 11:07:23 2005].449542
msConnPoolRegister(Oracle,user/passwd at BOX.os,0x82f7f98)
[Mon May 2 11:07:23 2005].455171 msOracleSpatialLayerFreeItemInfo was
called.
[Mon May 2 11:07:23 2005].513718 msOracleSpatialLayerGetItems was
called.
[Mon May 2 11:07:23 2005].514835 msOracleSpatialLayerInitItemInfo was
called.
[Mon May 2 11:07:23 2005].527714 msOracleSpatialLayerFreeItemInfo was
called.
[Mon May 2 11:07:23 2005].527815 msOracleSpatialLayerGetItems was
called.
[Mon May 2 11:07:23 2005].617739 msOracleSpatialLayerInitItemInfo was
called.
x: 0 - y: 0 [Mon May 2 11:07:23 2005].618040 msOracleSpatialLayerOpen
called with: GEOMETRIE from (SELECT * FROM FLURST) USING UNIQUE ID SRID
82027
[Mon May 2 11:07:23 2005].618059 msOracleSpatialLayerFreeItemInfo was
called.
[Mon May 2 11:07:23 2005].618075 msOracleSpatialLayerWhichShapes was
called.
[Mon May 2 11:07:23 2005].618136 msOracleSpatialLayerWhichShapes. Using
NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO_ORDINATE_ARRAY(3405582.22,5521435.53,3405582.22,5521435.53) ),'querytype=window') = 'TRUE'
[Mon May 2 11:07:23 2005].731214 msOracleSpatialLayerFreeItemInfo was
called.
[Mon May 2 11:07:23 2005].731264 msOracleSpatialLayerClose was called.
[Mon May 2 11:07:23 2005].731276 msOracleSpatialLayerClose. Cleaning
layerinfo handlers.
[Mon May 2 11:07:23 2005].731309 msOracleSpatialLayerClose. Cleaning
Oracle handlers.
[Mon May 2 11:07:23 2005].731321
msConnPoolRelease(Oracle,user/passwd at BOX.os,0x82f7f98)
[Mon May 2 11:07:23 2005].731337
msConnPoolClose(user/passwd at BOX.os,0x82f7f98)
Anzahl: 1 <br>0. ErgebnisstdClass Object
[shapeindex] => 0
[tileindex] => -1
[classindex] => 0
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 16384 (LWP 8349)]
msOracleSpatialLayerGetShape (layer=0x8285d60, shape=0x82df3e0,
record=0) at maporaclespatial.c:2003
2003 msOracleSpatialDataHandler *dthand =
(msOracleSpatialDataHandler *)layerinfo->oradatahandlers;
Am Montag, den 02.05.2005, 10:57 +0200 schrieb Bart van den Eijnden:
> Hi Nicol,
> In order to use query functionality you need to define a different DATA statement, something like:
> where ID is the name of your unique column (primary key most of the time).
> Best regards,
> Bart
> Syncera-ITSolutions
> Postbus 270
> 2600 AG DELFT
> >>> Nicol Hermann <mapserver at GEOWORLD.DE> 05/02/05 10:50am >>>
> Hi Fernando,
> thank you very much for your e-mail.
> I tried the latest CVS version ($Id: maporaclespatial.c,v 1.26
> 2005/04/28 22:19:41 rodrigo Exp $) with the '--enable-point-z-m'
> compiling flag but it did not change the situation.
> Mapserver crashes when it try to access the search results with:
> $shpobj = $Layer->getShape($oRes->tileindex,$oRes->shapeindex);
> I also found, that nearly the hole map-object is empty when i add the
> '--enable-point-z-m' compiling flag (see attached gdb output) and try to
> access it with PHP Mapscript.
> $map = ms_newMapObj('oracle_test_gk3.map') or die('Error.');
> var_dump($map);
> Removing this flag gives me the normal look.
> Here is my oracle layer definition.
> Yes i define a template, and no i did not define any filter parameter:
> LAYER
> NAME Oracle
> STATUS DEFAULT
> TYPE POLYGON
> DEBUG ON
> CONNECTIONTYPE oraclespatial
> CONNECTION "user/passwd at BOX.os"
> DATA "GEOMETRIE from FLURST USING SRID 82027"
> PROJECTION
> "init=epsg:31467"
> END
> CLASS
> NAME gw
> TEMPLATE "dummy.html"
> STYLE
> COLOR 192 192 192
> OUTLINECOLOR 0 0 0
> END
> END
> END
> Should i open a bug on this?
> Many thanks
> Nicol
> gdb-Output:
<cut old gdb output>
> Am Donnerstag, den 28.04.2005, 11:42 -0300 schrieb Fernando Simon:
> > Hi Nicol,
> > This problem can be a bug in maporaclespatial.c in 4.4.2 version.
> > In this version of Mapserver the maporaclespatial is a 1.16 version,
> > a old version (now it is a 1.25). I fixed some problems with OCI
> > handlers between 1.6 and 1.25, the last version 1.25 can work
> > correctly for you.
> > But, it's a strange problem, how did you define oracle spatial
> > layer? Did you define the template for the layer? Did you define any
> > filter parameter for the layer?
> > Thanks.
> > ps: for cvs version specify the --enable-point-z-m flag
> > Fernando Simon
> > Mapserver and Oracle Spatial developer
> > G10 - Laboratorio de Computacao Aplicada - Brazil
> > http://g10.cttmar.univali.br - UNIVALI/CTTMAR
> > Citando Nicol Hermann <mapserver at GEOWORLD.DE>:
> > > Dear list,
> > > I want to use the query function of the native Oracle Spatial
> > > support
> > > (INPUT=ORACLESPATIAL) from mapserver 4.4.2.
> > > Displaying the image is no problem but when try to get the query
> > > results
> > > mapserver crashes with a segmentation fault.
> > > Here is what i try to do:
> > > for($j = 0;$j < $Layer->getNumResults(); $j++) {
> > > $oRes = $Layer->getResult($j);
> > > Line which causes the Segmentation fault
> > > $shpobj->free();
> > > Is this a bug or do i have to change something?
> > > My system is:
> > > Debian sarge, mapserver 4.4.2 (php Mapscript), oracle 10g
> > > Attached you find the output of gdb.
> > Univali - Webmail - http://webmail.univali.br
