AW: [UMN_MAPSERVER-USERS] imagemap
Gernot Katzlberger
knozi at GMX.AT
Mon May 2 09:40:47 EDT 2005
I changed the data statement but nothing happened. It is still the same map
as before (without the ids). Can I define a column in the database which
will be taken by the imagemap for inserting the ids?
regards,
gernot
-----Ursprüngliche Nachricht-----
Von: Stéphane RIFF [mailto:stephane.riff at cerene.fr]
Gesendet: Montag, 02. Mai 2005 15:25
An: Gernot Katzlberger
Cc: MAPSERVER-USERS at LISTS.UMN.EDU
Betreff: Re: [UMN_MAPSERVER-USERS] imagemap
I think that the data return by '%s' in imagemap format is the first
filed of your datasource.
with a DATA pattern like this : DATA "geom from (select oid, geom from
geom_table) as foo"
you will gt what you want
Gernot Katzlberger wrote:
>Hi list,
>I'm trying to get the imagemap function working. I can create an output and
>an imagemap but the ids to the single polygons are missing. How do I get
the
>ids into the href of the imagemap? The ids should come out of the database.
>html-source:
>now:
><area href="map.php?id=" title="" shape="poly" coords=" 616,165, 616,167,
>613,168, 612,169, 616,165" />
><area href="/map.php?id=" title="" shape="poly" coords=", 607,164, 609,167,
>608,168, 608,169, 612,173, 607,164" />
>should be:
><area href="map.php?id=state01" title=" state01" shape="poly" coords="
>616,165, 612,169, 616,165" />
><area href="/map.php?id=state02" title=" state02" shape="poly" coords=",
>607,164, 612,173, 607,164" />
>I have a mapfile with the outputformat and one layer defined:
>OUTPUTFORMAT
> NAME imagemap
> DRIVER imagemap
> MIMETYPE text/html
> FORMATOPTION "POLYHREF=/verifier/map.php?state=%s"
> FORMATOPTION "SYMBOLHREF=#"
> FORMATOPTION "MAPNAME=image_map"
> FORMATOPTION "TITLE=image_map"
> FORMATOPTION "POLYMOUSEOUT=return nd();"
> FORMATOPTION "POLYMOUSEOVER=return overlib('%s');"
>END
>LAYER
> CONNECTION "user=user password=pwd dbname=db host=localhost"
> CONNECTIONTYPE POSTGIS
> DATA "the_geom from gd_poly_002"
> NAME "see01"
> STATUS ON
> TYPE POLYGON
> UNITS METERS
> CLASS
> NAME "class0"
> STYLE
> COLOR 189 215 231
> SYMBOL 0
> END
> END
> END
>Thanks,
>Gernot
